Parking brake cable removal #582438
01/14/10 05:14 PM
01/14/10 05:14 PM
PA
W
Waynes48 Offline OP
Waynes48  Offline OP
W
PA
Is there a secret trick, or special tool to remove the parking brake cable from the brake backing plate? It's a 8 3/4" rear. I was successful with one of the cables by using a hose clamp to squeeze the "barbs" enough to allow it to pass thru the mounting hole, but the remaining one is giving me fits. I don't want to damage the cable, but I'm quickly losing my patience. Can anyone offer a suggestion? Thanks.
Re: Parking brake cable removal [Re: Waynes48] #582439
01/14/10 05:29 PM
01/14/10 05:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Stick with the screw clamp it will work just relax.
Re: Parking brake cable removal [Re: stumpy] #582440
01/14/10 11:32 PM
01/14/10 11:32 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I usually slip a box end wrench over, and twist it around. Can't remember is it's 1/2" or 9/16"
Re: Parking brake cable removal [Re: dave571] #582441
01/14/10 11:50 PM
01/14/10 11:50 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Parking brake cable removal [Re: stumpy] #582442
01/14/10 11:58 PM
01/14/10 11:58 PM
Stick with the screw clamp it will work.
take your time & have the clamp a hair from the end of the tines so when they're compressed enough they can start thru as you keep pressure on the cable pushing it as you unscrew the clamp.
Re: Parking brake cable removal [Re: dave571] #582443
01/15/10 12:22 AM
01/15/10 12:22 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
slip it over, rotate wrench and tug the cable out.
Re: Parking brake cable removal [Re: nomore65BelvJim] #582444
01/15/10 12:29 AM
01/15/10 12:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some of the most creative swearing I've ever done came out the first time I battled that.
Re: Parking brake cable removal [Re: Waynes48] #582445
01/15/10 02:34 AM
01/15/10 02:34 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I compress the tangs with a 9/16" boxed end wrench and yank the cable out.
Re: Parking brake cable removal [Re: stumpy] #582446
01/15/10 05:05 PM
01/15/10 05:05 PM
PA
W
Waynes48 Offline OP
Waynes48  Offline OP
W
PA
Finally got it using the hose clamp. Tried the box wrench method, but I couldn't get it with that. I hope I won't have to do that again.
