How do I increase idle speed on my '99 durango? #582363
01/14/10 04:31 PM
01/14/10 04:31 PM
Rochester, NY
dusterdood Offline OP
Rochester, NY
Just a bit. When it's as cold out as it is now (below freezing) my 1999 durango idles below 600 RPM. It'll stall if I don't put my foot on the gas. I only need the idle up 100-200 RPM, and it would be fine. Once warmed up it'll idle that low, so I guess I could live with it, but how can I turn it up? The distributer doesn't change timing, right?
Mike
Re: How do I increase idle speed on my '99 durango? [Re: dusterdood] #582364
01/14/10 04:36 PM
01/14/10 04:36 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
Im not sure but you might want go to an auto parts store and run a scan for free to see if theres a bad sensor.
Re: How do I increase idle speed on my '99 durango? [Re: dodger1] #582365
01/14/10 04:49 PM
01/14/10 04:49 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You dont. The idle speed is flashed into the PCM.
If you try messing with the idle speed by adjusting the throttle blade screw I believe the IAC solenoid will compensate and bring it back.
I think it might be able to be done with a scanner though.
Perhaps a mopar tech will chime in and correct me if I'm wrong.
Re: How do I increase idle speed on my '99 durango? [Re: POS Dakota] #582366
01/14/10 04:56 PM
01/14/10 04:56 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
it SHOULD want to idle higher until it warms up. all the fuel injected vehicles I've had, all wanted to idle at 900-1200 rpm the first few minutes of a cold start, and as it warms up, back down to 600-700. I would check all your sensors. you might have a bad intake temperature sensor, bad idle control solenoid, bad coolant sensor, etc.
**Photobucket sucks**
Re: How do I increase idle speed on my '99 durango? [Re: 70Cuda383] #582367
01/14/10 05:05 PM
01/14/10 05:05 PM
Rochester, NY
Rochester, NY
I don't have any check engine lights on, and I thought if something was out of wack it would trigger the check light. Can I have a bad sensor that doesn't trigger the idiot light?
Re: How do I increase idle speed on my '99 durango? [Re: dusterdood] #582368
01/14/10 05:19 PM
01/14/10 05:19 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Your IAC is bad.
Re: How do I increase idle speed on my '99 durango? [Re: fox] #582369
01/14/10 05:28 PM
01/14/10 05:28 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
There are a number of things that can be out of spec and not turn the check engine light on. Have it checked for codes at the local parts store for free.
Re: How do I increase idle speed on my '99 durango? [Re: stumpy] #582370
01/14/10 05:36 PM
01/14/10 05:36 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Your IAC is bad.
THat's where I was leaning too. I've seen them get all carboned up. May just need a cleaning. The throttlebody could use a cleaning too.
If that doesn't help you can just remove the gasket from the plate on the bottom of the intake...that will get the idle up to where it won't stall...
Re: How do I increase idle speed on my '99 durango? [Re: stumpy] #582371
01/14/10 05:43 PM
01/14/10 05:43 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
I would change the pcv valve it could be bad
Re: How do I increase idle speed on my '99 durango? [Re: dusterdood] #582372
01/14/10 07:19 PM
01/14/10 07:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I would check the coolant sensor,that is the first thing that determines the amount of fuel on start regardless of outside temperature.Don't confuse it with the temperature sensor,totaly different.Also,make sure the IAC if free from carbon.
Re: How do I increase idle speed on my '99 durango? [Re: dusterdood] #582373
01/14/10 07:54 PM
01/14/10 07:54 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
You might try spraying some throttle body cleaner into the throttle body, the IAC controls the air through an orifice in the throttle body and, if the orifice is plugged with carbon, the idle will be off spec.
Re: How do I increase idle speed on my '99 durango? [Re: John_Kunkel] #582374
01/14/10 08:08 PM
01/14/10 08:08 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Another vote for the IAC.
Carb cleaner might fix the problem.
Re: How do I increase idle speed on my '99 durango? [Re: Leadfoot] #582375
01/14/10 10:08 PM
01/14/10 10:08 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
Does it crank over good and strong?? A weak battery will cause the computer too lose memory and cause that problem.Idles fine after a few minutes running because the computer has relearned idle.Clean the crude out of the iac port and the throttle body.Black stuff around the butterflies keeps the air out.it needs some.If all that is clean and still have problems there is a small idle stop srew.remove the factory cap, and you can turn it slightly.back side of throttle body,against the throttl shaft/linkage.If you need more than a half turn,Then you have more problems.Don't keep turning it too correct another problem.That will change the t.p.s. senor reading and will cause other problems.Stuck idle motor could also be a problem.Before you start guessing and throwing parts at it.CLEAN first.and check battery.
Re: How do I increase idle speed on my '99 durango? [Re: Leadfoot] #582376
01/14/10 11:15 PM
01/14/10 11:15 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Me three, or 4 or how evermany this is now.
It is likely stuck. May be no good now, but cleaning it may work out for you.
Re: How do I increase idle speed on my '99 durango? [Re: dave571] #582377
01/15/10 06:28 AM
01/15/10 06:28 AM
Rochester, NY
Rochester, NY
Thanks for all the help everyone. It does crank strong, although the battery is suspect. It's out of another one of my cars, that sat all last summer. I'll break out the DMM, and check the system, and the carb cleaner and clean out the IAC/throttle body. The weather has changed, and it's above freezing all this weekend, so that's good timing!
Mike
Re: How do I increase idle speed on my '99 durango? [Re: dusterdood] #582378
01/15/10 10:26 AM
01/15/10 10:26 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
If everyones suggestions don't help you, there is one more thing to check.
This would involve using a DBR scan tool like the factory or dealership should have.
If the distributor has moved a hair it will effect the fuel curve. This setting can only be re-established with the DBR scan tool. The goal is to acheive 0, plus or minus 1, as the distributor is tighten down.
I recently did this job for a buddy when I sold him my 1999 Dakota R/T motor. The motor was converted to a stock type distributor for when I was going to use it in a car, then returned back to stock factory pieces and EFI.
I learned something new. Timing is 100% controlled electronically, the distributor position sets the fuel. This can not be done properly without something like a DBR scan tool.
I kind of got the vehicle going by trial and error, but it runs like a clock when the procedure is done. Power and fuel economy were restored.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: How do I increase idle speed on my '99 durango? [Re: racealittle] #582379
01/15/10 11:37 AM
01/15/10 11:37 AM
Rochester, NY
Rochester, NY
I pulled out the IAC, and cleaned the throttle body with carb cleaner. The new one was only $43, so I bought one, and just dropped it in. Everything is fixed. Thanks for all the help guys.
Mike
