Re: How do I increase idle speed on my '99 durango?
[Re: POS Dakota]
#582366
01/14/10 04:56 PM
01/14/10 04:56 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
it SHOULD want to idle higher until it warms up. all the fuel injected vehicles I've had, all wanted to idle at 900-1200 rpm the first few minutes of a cold start, and as it warms up, back down to 600-700. I would check all your sensors. you might have a bad intake temperature sensor, bad idle control solenoid, bad coolant sensor, etc.
**Photobucket sucks**
[Re: stumpy]
#582370
01/14/10 05:36 PM
01/14/10 05:36 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Your IAC is bad.
THat's where I was leaning too. I've seen them get all carboned up. May just need a cleaning. The throttlebody could use a cleaning too.
If that doesn't help you can just remove the gasket from the plate on the bottom of the intake...that will get the idle up to where it won't stall...
[Re: dusterdood]
#582373
01/14/10 07:54 PM
01/14/10 07:54 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You might try spraying some throttle body cleaner into the throttle body, the IAC controls the air through an orifice in the throttle body and, if the orifice is plugged with carbon, the idle will be off spec.
[Re: Leadfoot]
#582376
01/14/10 11:15 PM
01/14/10 11:15 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Another vote for the IAC. Carb cleaner might fix the problem.
Me three, or 4 or how evermany this is now.
It is likely stuck. May be no good now, but cleaning it may work out for you.
[Re: dusterdood]
#582378
01/15/10 10:26 AM
01/15/10 10:26 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
If everyones suggestions don't help you, there is one more thing to check.
This would involve using a DBR scan tool like the factory or dealership should have.
If the distributor has moved a hair it will effect the fuel curve. This setting can only be re-established with the DBR scan tool. The goal is to acheive 0, plus or minus 1, as the distributor is tighten down.
I recently did this job for a buddy when I sold him my 1999 Dakota R/T motor. The motor was converted to a stock type distributor for when I was going to use it in a car, then returned back to stock factory pieces and EFI.
I learned something new. Timing is 100% controlled electronically, the distributor position sets the fuel. This can not be done properly without something like a DBR scan tool. I kind of got the vehicle going by trial and error, but it runs like a clock when the procedure is done. Power and fuel economy were restored.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
