Need a little help with tire on a Hemi Dart #581678
01/13/10 09:48 PM
01/13/10 09:48 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hello everybody. Need a little help trying to figure out what tires they used on a Hemi Dart when they left the Hurst plant.
The front tires had a part number of 2834950. They were a D70x14 Black wall tire but were they Firestone, Goodyear's or BFGs??
The Back tires had a part number of 2462274. They were a 7.75x15 Black wall tire and I don't know what brand of tire those were either.
What do you think???
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581679
01/13/10 10:34 PM
01/13/10 10:34 PM
Detroit, MI
David Hakim Offline
super street
David Hakim  Offline
super street
Detroit, MI
Goodyear.
Re: Need a little help with tire on a Hemi Dart [Re: David Hakim] #581680
01/14/10 12:18 AM
01/14/10 12:18 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi David, hope all is well with you. I was thinking Good year but what model would they be?? Speedways??? Are they Red or Blue dots that were turned around???
Here is the best picture I have of an original rear tire and I just can't pick anything off of it that is legible.
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581681
01/14/10 01:45 AM
01/14/10 01:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The D70-14 was the minimum size required on Darts & Barracudas with disc brakes & I'd "assume" they were blackwall "SPEEDWAY"s.
Do you have any other pics, front or rear & any showing tread?
The 7.75-15 were probably blackwall "POWER CUSHION"s.
I doubt they would've turned a more costly "blue dot" or "red stripe" around. They were just cheap "rollers".
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581682
01/14/10 02:35 AM
01/14/10 02:35 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is this a 42 year old photo?
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581683
01/14/10 06:54 AM
01/14/10 06:54 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Gee, they weren't very gentle with beating the quarter into submission were they?
I can't afford this. mark
Re: Need a little help with tire on a Hemi Dart [Re: a12superbee] #581684
01/14/10 11:04 AM
01/14/10 11:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Where did that picture of the front tires go that was posted last night?
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581685
01/14/10 11:43 AM
01/14/10 11:43 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi Dan
Yes, this is an original photo. How in the heck did you get that photo to the point where you could read all that!?!?
Re: Need a little help with tire on a Hemi Dart [Re: a12superbee] #581686
01/14/10 12:01 PM
01/14/10 12:01 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
.....they were cut with a Sawzall and those black marks are suet left over from brazing up the corners of the wheel well.
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581687
01/14/10 02:54 PM
01/14/10 02:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
These scans are from a Goodyear Jan. '72 Discontinued Tires sheet.
I believe these would be the rears. **** 7.75-15 POWER CUSHION (BL)
edit Actually I don't think these are the rear tires I was going to ask if they would've mixed polyester and nylon tires on the same car. Size and name are correct, just an earlier version "2 Ply nylon POWER CUSHION"
From KELSEY TIRE's website:
All non-Corvette O.E. 775/15 applications were fitted with the Goodyear Power Cushion broad market tire. Although identical in design optics, this tire carried inflated dimensions resulting in a taller O.D. and narrower inflated section width and tread radius.
Construction:2-ply nylon tubeless.
I think the tire you'd be looking for is this nylon "Power Cushion broad market tire".
NOT the tire shown/listed below
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581688
01/14/10 02:58 PM
01/14/10 02:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Was there a picture of the fronts?
I'm guessing the D70-14 (BL) was previously discontinued, I'll look some more.
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581689
01/14/10 03:42 PM
01/14/10 03:42 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
....I never had a picture of the front up there. I don't have a good picture of the fronts. I have one other picture that I will post later with some info on it.
I'll tell ya, I don't know what to do with this car when it comes to tires. It is a clone car, it will make 520hp (472 with headers and small roller cam) but I want it to look like it did when it left Hurst.
Lets think about this.....510hp and 11.5" of rear rubber. That will make plenty of
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581690
01/14/10 04:07 PM
01/14/10 04:07 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I doubt anyone with a new Super Stock Dart or Barracuda tried to make a serious 1/4-mile pass with the 7.75-15s.
Sounds like you'll need (at least) two sets of rear tires!
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581691
01/14/10 11:20 PM
01/14/10 11:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Someone late last night posted a current picture of a front tire on a Dart. But then deleted the post. It was Super Streak or something. Have no idea what car it was from. The poster was from Canada, but I forgot his username.
Re: Need a little help with tire on a Hemi Dart [Re: autoxcuda] #581692
01/15/10 02:17 AM
01/15/10 02:17 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
at See full size image
See full size image
at: www.moparsbymosher.com/ they say the is g70-14 tire
but at www.ssandafx.com they say is a BF Goodrich Silvertown 6.40-15 front tires 27in.
i need a beer
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Need a little help with tire on a Hemi Dart [Re: 440beep] #581693
01/15/10 02:32 AM
01/15/10 02:32 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
This should shead a little light on things....You might have to down load it and then blow it up.
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581694
01/15/10 02:37 AM
01/15/10 02:37 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Here is another photo that Dan might be able to play with and see something..
Re: Need a little help with tire on a Hemi Dart [Re: Troy] #581695
01/15/10 03:16 AM
01/15/10 03:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Can't get anything from the pic.
Do have a couple questions from the change order.
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581696
01/15/10 10:36 AM
01/15/10 10:36 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Just a guess here but could 2539093 could be the part number for the 8 3/4 4:86 rear.
If that were the case, 0/W order with 2539093 could mean order the 4:86 8/34.
QTY 4 (in the same column) would mean the 4 6:95-14 BSW tires which would come with the 8 3/4 rear.
2834948 could be the part number for the 9 3/4 4:88 Dana , thus 0/W ordering with 2834948 would get you QTY 2 (in the same column) 2 tires D-70-14 on the front and 15's on the dana rear.
Re: Need a little help with tire on a Hemi Dart [Re: 6bblgt] #581697
01/15/10 12:31 PM
01/15/10 12:31 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi Dan.
Yes, that is a 4" bolt circle rim....that is why that number is in the DELETE column. They used 4.5 bolt circle front and rear wheels on these cars.
O/W???? I'm not sure either....still working on it.
Thanks for trying to read that photo, it was worth a shot.
