Need a little help with tire on a Hemi Dart
#581678
01/13/10 09:48 PM
01/13/10 09:48 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Hello everybody. Need a little help trying to figure out what tires they used on a Hemi Dart when they left the Hurst plant.
The front tires had a part number of 2834950. They were a D70x14 Black wall tire but were they Firestone, Goodyear's or BFGs??
The Back tires had a part number of 2462274. They were a 7.75x15 Black wall tire and I don't know what brand of tire those were either.
What do you think???
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Need a little help with tire on a Hemi Dart
[Re: David Hakim]
#581680
01/14/10 12:18 AM
01/14/10 12:18 AM
Troy
West Coast, CA
Hi David, hope all is well with you. I was thinking Good year but what model would they be?? Speedways??? Are they Red or Blue dots that were turned around???
Here is the best picture I have of an original rear tire and I just can't pick anything off of it that is legible.
[Re: Troy]
#581681
01/14/10 01:45 AM
01/14/10 01:45 AM
Posts: 17,519 Las Vegas, NV
6bblgt
Las Vegas, NV
The D70-14 was the minimum size required on Darts & Barracudas with disc brakes & I'd "assume" they were blackwall "SPEEDWAY"s. Do you have any other pics, front or rear & any showing tread? The 7.75-15 were probably blackwall "POWER CUSHION"s. I doubt they would've turned a more costly "blue dot" or "red stripe" around. They were just cheap "rollers".
[Re: 6bblgt]
#581685
01/14/10 11:43 AM
01/14/10 11:43 AM
Troy
West Coast, CA
Hi Dan Yes, this is an original photo. How in the heck did you get that photo to the point where you could read all that!?!?
[Re: Troy]
#581687
01/14/10 02:54 PM
01/14/10 02:54 PM
6bblgt
Las Vegas, NV
These scans are from a Goodyear Jan. '72 Discontinued Tires sheet. I believe these would be the rears. **** 7.75-15 POWER CUSHION (BL) edit Actually I don't think these are the rear tires I was going to ask if they would've mixed polyester and nylon tires on the same car. Size and name are correct, just an earlier version "2 Ply nylon POWER CUSHION"From KELSEY TIRE's website: Quote:
All non-Corvette O.E. 775/15 applications were fitted with the Goodyear Power Cushion broad market tire. Although identical in design optics, this tire carried inflated dimensions resulting in a taller O.D. and narrower inflated section width and tread radius.
Construction:2-ply nylon tubeless.
I think the tire you'd be looking for is this nylon "Power Cushion broad market tire".
NOT the tire shown/listed below
[Re: 6bblgt]
#581689
01/14/10 03:42 PM
01/14/10 03:42 PM
Troy
West Coast, CA
....I never had a picture of the front up there. I don't have a good picture of the fronts. I have one other picture that I will post later with some info on it. I'll tell ya, I don't know what to do with this car when it comes to tires. It is a clone car, it will make 520hp (472 with headers and small roller cam) but I want it to look like it did when it left Hurst. Lets think about this.....510hp and 11.5" of rear rubber. That will make plenty of
[Re: 6bblgt]
#581691
01/14/10 11:20 PM
01/14/10 11:20 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Was there a picture of the fronts?
I'm guessing the D70-14 (BL) was previously discontinued, I'll look some more.
Someone late last night posted a current picture of a front tire on a Dart. But then deleted the post. It was Super Streak or something. Have no idea what car it was from. The poster was from Canada, but I forgot his username.
[Re: autoxcuda]
#581692
01/15/10 02:17 AM
01/15/10 02:17 AM
Posts: 1,183 eganville ont
440beep
eganville ont
at See full size image See full size image ... . at: www.moparsbymosher.com/ they say the is g70-14 tire but at www.ssandafx.com they say is a BF Goodrich Silvertown 6.40-15 front tires 27in. i need a beer
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 440beep]
#581693
01/15/10 02:32 AM
01/15/10 02:32 AM
Troy
West Coast, CA
This should shead a little light on things....You might have to down load it and then blow it up.
[Re: Troy]
#581694
01/15/10 02:37 AM
01/15/10 02:37 AM
Troy
West Coast, CA
Here is another photo that Dan might be able to play with and see something..
