Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581476
01/15/10 03:59 PM
01/15/10 03:59 PM
cataclysm80 Offline
cataclysm80  Offline
The 1970 door has a round hole here. It is not a slotted oval for adjustment like later doors have.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581477
01/15/10 11:14 PM
01/15/10 11:14 PM
cataclysm80 Offline
cataclysm80  Offline
This non-1970 door has an oval hole to allow the guide some in/out adjustment.
There are also some extra holes. Any idea what they're for?
You can see in this picture where the round cat whiskar holes were at before I made them oval like the 1970 door.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581478
01/15/10 11:19 PM
01/15/10 11:19 PM
cataclysm80 Offline
cataclysm80  Offline
The 1970 door has an access hole here by the window crank. If I remember correctly, it adjusts something on the manual window regulator. This hole isn't in the later doors. I guess they decided it wasn't necessary.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581479
01/15/10 11:23 PM
01/15/10 11:23 PM
cataclysm80 Offline
cataclysm80  Offline
This non-1970 door doesn't have the access hole you saw in the last picture.
It does have an extra hole that is not on the 1970 door though. I'm not sure what this hole is for. It is not used for either the manual or power window regulators. Any ideas?
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581480
01/15/10 11:26 PM
01/15/10 11:26 PM
cataclysm80 Offline
cataclysm80  Offline
Here's the 1970 door again, showing the oval cat whiskar holes.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581481
01/15/10 11:35 PM
01/15/10 11:35 PM
cataclysm80 Offline
cataclysm80  Offline
Here is the same area on the non-1970 door. Compare it to the picture above.
Again, you can see where I made the round cat whiskar holes oval shaped to accept the clips on my 1970 cat whiskar set. My cat whiskar set is reproduction, and doesn't have a clip in one of the factory locations, so I didn't bother to make the unused hole oval shaped.
There is an oval hole for an extra window guide that was added after 1970.
There are also some other extra holes, and part of the door is actually stamped a different shape.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581482
01/15/10 11:38 PM
01/15/10 11:38 PM
cataclysm80 Offline
cataclysm80  Offline
Looking down inside the 1970 door.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581483
01/15/10 11:39 PM
01/15/10 11:39 PM
cataclysm80 Offline
cataclysm80  Offline
Looking down inside the non-1970 door, you can see the double thick sheetmetal.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581484
01/15/10 11:40 PM
01/15/10 11:40 PM
cataclysm80 Offline
cataclysm80  Offline
Well, that's about all I've got so far. Hope that helps.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581485
01/16/10 07:34 AM
01/16/10 07:34 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: 70-74 Dodge Challenger Doors [Re: Roppa440] #581486
01/16/10 08:19 AM
01/16/10 08:19 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Cool detailed posts Tav!
My only comment would be the 'top of door trim' (belt moulding).
For a 'Cuda - '70 used a series of plastic clips to hold it (with one metal on the end), whereas later years had the little studs welded to the top of the door.
For Challengers, which used stainless steel for their moulding, IIRC all of the clips were metal of one description or another and would've been drilled into the door. I'll see if I have any SE moulding at the house that I can check.
If the post is still going in a few months, I'll take some photos of my door collection which includes '70s, '71s and later years....
Re: 70-74 Dodge Challenger Doors [Re: YYZ] #581487
01/16/10 10:14 PM
01/16/10 10:14 PM
cataclysm80 Offline
cataclysm80  Offline
Thanks for correcting me YYZ, I've edited my post above.
I have 1 set of the 'cuda belt moldings & clips off a 1970 'cuda, and 2 sets of the Challenger belt moldings off of unknown Challengers.
I totally agree with what you said about the 'cuda moldings.
Yes, the Challenger moldings are stainless instead of aluminum. (I just checked.) Unfortunately I don't have much in the way of clips for the Challenger pieces. I have one metal clip for each side of the car. (I got the set with 2 clips from Ken Mosier at The Finer Details.) I'm not sure what clips would be used on Challengers. Info appreciated
P.S. Just to make sure no one is confused, The molding on the top of the doors is called belt molding, and on Challengers it is commonly referred to as SE molding. The reason is that this molding came standard on the SE cars. However, it Was Also available as an option on other Challengers in 70 & 71.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581488
02/04/10 09:30 AM
02/04/10 09:30 AM
cataclysm80 Offline
cataclysm80  Offline
I saw in another thread that the 70-71 doors have dimples where the screws go for the convertible door wedges, and that the 72-74 doors don't have these dimples.
Just thought I should add that info to this thread.
Tav
Re: 70-74 Dodge Challenger Doors [Re: cataclysm80] #581489
09/13/13 06:09 PM
09/13/13 06:09 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
Hi peeps,
found this very interesting topic and like to add some questions.
Looking down inside the above 70 door, does not show the attached bracket on the drivers side, that I have in my car. As I remembered I saw this bracket already.
I cannot see what the bracket is for in my car. Any ideas?
Many thanks.
Thomas
Re: 70-74 Dodge Challenger Doors [Re: walkAbout] #581490
09/13/13 06:12 PM
09/13/13 06:12 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
Here the pic that I downloaded for comparison. But I think it is shown on the wrong place.
Thomas
Re: 70-74 Dodge Challenger Doors [Re: walkAbout] #581491
09/13/13 06:14 PM
09/13/13 06:14 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
And here too, advertised as "NOS mirror attachment kit for driver's side remote mirrors".
Thomas
Re: 70-74 Dodge Challenger Doors [Re: walkAbout] #581492
09/16/13 05:35 PM
09/16/13 05:35 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Tav,
The 2 extra holes below where the cat whiskers go are for a small metal bracket that has a hair-like appearance (anti-rattle clip). There are 2 small Phillips screws that retain the the bracket.
Chuck
When you work on Spaceships for a living, how bad can a workday be?
Re: 70-74 Dodge Challenger Doors [Re: dart440] #581493
09/18/13 09:05 AM
09/18/13 09:05 AM
Home of the Bluegrass
MoparJunkie Online content
MoparJunkie  Online Content
Anyone have a picture of those anti rattle clips installed on a '70 door? Also did '70 come with 2 anti rattle clips and 2 window stop bumps at the top of the doors for the glass?
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 70-74 Dodge Challenger Doors [Re: MoparJunkie] #581494
09/18/13 06:01 PM
09/18/13 06:01 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
Here you go...
Hard for me to answer, as I have to different doors. My drivers side is original and has 2 anti rattle clips to the glass from the inside. On the anti rattle clip pic you can see that it is outside on the passenger side on my car, but is is a door from another car. Still has those oval holes for the cat whiskers..
I made a video of this stuff for documentation and comparison of the 2 doors, unfortunately I spoke german this time in the video. Door is still open with new rollers, maybe I will redo the video in english.
CU
walkAbout
