Installing a 10.95 clutch
#581409
01/13/10 06:59 PM
01/13/10 06:59 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
Hello, Does anyone know the pars I need to install a 10.95 (scalloped) clutch on a 130 tooth flywheel (10.5 orig clutch) w/ 23 spline input. I googled it with no details given... For centerforce is this the clutch I want: http://www.summitracing.com/parts/CTF-DF070800/what bolts? - I know they are special
Re: Installing a 10.95 clutch
[Re: 68LAR]
#581412
01/13/10 09:03 PM
01/13/10 09:03 PM
6T6Cuda
Cincinnati, OH
The first thing you will need to do is verify that the 10.95 (11") will bolt up to your flywheel. I'm pretty sure they (10.5 & 10.95 or 11), have different bolt patterns. As far as the attachment bolts, stock bolts will work, but must be at least a grade 8. Summit has them listed. 3/8-24X1 I believe. The part number you have for CenterForce is correct.
So while they are 130 tooth, they are two different flywheel bolt patterns? I assume most of the aftermarket (hayes, mclead, centerofrce, etc...) will have both patterns or would that be too much to ask? Anyone know for sure?
[Re: ogopogo]
#581424
01/18/10 10:45 AM
01/18/10 10:45 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I bought the correct bolts for mine at the local auto parts store,I'm pretty sure they were Mr Gasket brand,summit should have them.
that's the only type of bolt I have ever seen sold as pressure plate attching bolts .
