Installing a 10.95 clutch #581409
01/13/10 06:59 PM
01/13/10 06:59 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Hello,
Does anyone know the pars I need to install a 10.95 (scalloped) clutch on a 130 tooth flywheel (10.5 orig clutch) w/ 23 spline input.
I googled it with no details given...
For centerforce is this the clutch I want:
http://www.summitracing.com/parts/CTF-DF070800/
what bolts? - I know they are special
Re: Installing a 10.95 clutch [Re: 6T6Cuda] #581410
01/13/10 07:15 PM
01/13/10 07:15 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
The first thing you will need to do is verify that the 10.95 (11") will bolt up to your flywheel. I'm pretty sure they (10.5 & 10.95 or 11), have different bolt patterns. As far as the attachment bolts, stock bolts will work, but must be at least a grade 8. Summit has them listed. 3/8-24X1 I believe. The part number you have for CenterForce is correct.
Re: Installing a 10.95 clutch [Re: 68LAR] #581411
01/13/10 07:49 PM
01/13/10 07:49 PM
Jamey Offline
Jamey  Offline
I'm running a 10.95 clutch on my 130 tooth centerforce flywheel. no problems.
Re: Installing a 10.95 clutch [Re: 68LAR] #581412
01/13/10 09:03 PM
01/13/10 09:03 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
So while they are 130 tooth, they are two different flywheel bolt patterns? I assume most of the aftermarket (hayes, mclead, centerofrce, etc...) will have both patterns or would that be too much to ask? Anyone know for sure?
Re: Installing a 10.95 clutch [Re: 6T6Cuda] #581413
01/13/10 10:25 PM
01/13/10 10:25 PM
Jamey Offline
Jamey  Offline
My centerforce only has one bolt pattern. I'd have to check if it has a part # on it.
Re: Installing a 10.95 clutch [Re: Jamey] #581414
01/13/10 10:27 PM
01/13/10 10:27 PM
Jamey Offline
Jamey  Offline
What engine are you putting that clutch behind? I had one behind my 440 and it ate it this past summer. I am running a mcleod now and like it better.
Re: Installing a 10.95 clutch [Re: 6T6Cuda] #581415
01/13/10 10:32 PM
01/13/10 10:32 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
10.5 and 10.95 clutches use the same bolt pattern but the 10.95 uses bolts with small heads for extra disc to bolt clearance. Kind of like a bb 7/16" header bolt but with a larger shoulder to properly locate the pressure plate
Re: Installing a 10.95 clutch [Re: 446acuda] #581416
01/13/10 11:53 PM
01/13/10 11:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Make sure that you check the O.D. on the clutch plate and make sure that it is 10.95". I have seen a few 10.95" clutch plates that were actually 11" plates. You wouldn't think that .050" was a big deal, but if you only have .045" of clearance, it is a big deal.
10.5" Flywheel and scalloped 10.95" pressure plate.
Re: Installing a 10.95 clutch [Re: Snoopy] #581417
01/13/10 11:54 PM
01/13/10 11:54 PM
Snoopy Offline
Snoopy  Offline
Dual pattern flywheel. I can't remember the brand.
Re: Installing a 10.95 clutch [Re: Snoopy] #581418
01/13/10 11:55 PM
01/13/10 11:55 PM
Snoopy Offline
Snoopy  Offline
Special bolt.
Re: Installing a 10.95 clutch [Re: Snoopy] #581419
01/14/10 10:58 AM
01/14/10 10:58 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Cool thanks...
Anyone have part numbers for the bolts? - Summit does not have enough of a description to tell the difference.
It is going behind a 408 360 balanced factory flywheel.
Re: Installing a 10.95 clutch [Re: 6T6Cuda] #581420
01/17/10 04:10 PM
01/17/10 04:10 PM
Snoopy Offline
Snoopy  Offline
I bought mine from Bob Mazzolini Racing.
They might also be used for headers.
1/2" Hex head.
Re: Installing a 10.95 clutch [Re: Snoopy] #581421
01/17/10 09:21 PM
01/17/10 09:21 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Snoopy, That bolt shoulder does not look long enough. The shoulder should actually go into the flywheel itself and "locate" it. The threads in the flywheel do not start right away to provide for this. Otherwise you are putting all that engine torque on the threads of the 6 flywheel bolts.
Re: Installing a 10.95 clutch [Re: hemi70se] #581422
01/17/10 10:41 PM
01/17/10 10:41 PM
Snoopy Offline
Snoopy  Offline
I have 3/8" of thread engagement and the shoulder extends a little over an 1/8" into the flywheel. The end of the bolt is .220" from the front of the flywheel.
The bolt could be 3/16" longer, but I don't think the shoulder would be any longer. The counter bore in the flywheel is 1/4" deep and the the pressure plate is 1/8" thick. The shoulder on the bolt is 1/4".
Re: Installing a 10.95 clutch [Re: Snoopy] #581423
01/18/10 04:38 AM
01/18/10 04:38 AM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
I bought the correct bolts for mine at the local auto parts store,I'm pretty sure they were Mr Gasket brand,summit should have them.
Re: Installing a 10.95 clutch [Re: ogopogo] #581424
01/18/10 10:45 AM
01/18/10 10:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that's the only type of bolt I have ever seen sold as pressure plate attching bolts .
Re: Installing a 10.95 clutch [Re: JohnRR] #581425
01/23/10 09:46 AM
01/23/10 09:46 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Thanks to everyone for the info...- I was a bit confused by exactly what bolts and everything, so I called Jamie and bought everything from him - got a good deal too..
THANKS for the info!
