Rear housing identification #581366
01/13/10 04:47 PM
01/13/10 04:47 PM
PA
W
Waynes48 Offline OP
Waynes48  Offline OP
W
PA
Is there a part number stamped into the Mopar rear end housing? I have what I believe to be a rear housing from a 68 or 69 Roadrunner, but I'd like to confirm that. The spring perches have been cut off, so I can't take a measurement there. If there is a part number for just the housing, where would I look? Thanks.
Re: Rear housing identification [Re: Waynes48] #581367
01/13/10 05:36 PM
01/13/10 05:36 PM
scratchnfotraction Offline
I take it it is a 8 3/4 housing?
look in the archives for the axle sizes flange to flange on the housings
whats the flange to flange measurment on the housing you have?
Re: Rear housing identification [Re: Waynes48] #581368
01/13/10 08:27 PM
01/13/10 08:27 PM
No numbers as far as I know. What he said, measure your flange to flange distance & go to the archives & if they're all different & you find your dimention you got it.
Re: Rear housing identification [Re: scratchnfotraction] #581369
01/13/10 08:53 PM
01/13/10 08:53 PM
PA
W
Waynes48 Offline OP
Waynes48  Offline OP
W
PA
It is indeed a 8 3/4" unit. Flange to Flange looks to be approximately 55 1/8", which according to the info I found in the archives would probably be 62-70 B-body. Thank you for the help.
Re: Rear housing identification [Re: Waynes48] #581370
01/13/10 09:29 PM
01/13/10 09:29 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
62-65 is not as long as 66-70
Re: Rear housing identification [Re: Waynes48] #581371
01/14/10 04:47 PM
01/14/10 04:47 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The chart that shows the '62-'70 B body rears as being the same is wrong (I wish somebody would delete it), the correct info is here:
http://www.moparts.org/Tech/Archive/axle/16.html
