71 up B/E body 3 speed wiper switch
#58118
05/09/08 07:33 PM
05/09/08 07:33 PM
OK I have a gentleman looking for some parts for a 71 B body, a 3 speed wiper switch being one of them. I have pulled a couple here (see pic)from 71-4 B clusters with the # 3488766. I searched ebay for a baseline price, and see this switch listed for E body (correct for 72-4 the ad says) I looked up the part for all 4 years B or E and come up with 2 different #'s, both of which seemed to go straight NLS, not superceding. Is this switch goint to be right for him? I just want to be sure I send the right stuff. (I think it is correct)
Re: 71 up B/E body 3 speed wiper switch
#58119
05/09/08 08:37 PM
05/09/08 08:37 PM
WITH rally gages or WITHOUT rallye gages photo is e body left b-body right
#58120
05/09/08 08:42 PM
05/09/08 08:42 PM
#58121
05/09/08 09:02 PM
05/09/08 09:02 PM
w/gauges my photos are correct tom
#58122
05/09/08 09:25 PM
05/09/08 09:25 PM
So the # on the B body one you have is 3488043? The one I have pictured is what I wonder then...it goes off, click click click like a 3 speed should.
#58123
05/09/08 09:42 PM
05/09/08 09:42 PM
yours would be a 72-74 w rallye gauges part number 3621672 casting number 3488766 sop (sop= stamped on part) note b and e do not interchange due to pole lenth
#58124
05/09/08 09:45 PM
05/09/08 09:45 PM
Perfect thanks. The pole length is an issue that makes sense, the guys on ebay are trying to flog the B body 72-4 as an E body one for $$$ go figure.
#58125
05/09/08 09:50 PM
05/09/08 09:50 PM
as said in another post there are those who choose not look it up in the parts book.
but i will say some of these switchs do look the same with out both together
#58126
05/09/08 09:58 PM
05/09/08 09:58 PM
that is why I made this post. I believe the one I have should then "work" in a 71, just not look correct, as the pole length does fit in the 71 cluster.
#58127
05/10/08 02:11 AM
05/10/08 02:11 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
the big round ones you have are not 3 speeds, are VARIABLE speed. Turn it and will find only have one click, the on/off one, and then a continuous fade up to top
the first pic is three speeds 72/74 ( not anymore variable available )... just some earliers 72 that came out with 71 switch. 74 came out with diff PN I think but same switch
I don't have in hands right now the 71 variable I have around but I'm pretty sure the longer one is 71 B body by the PN I remember.
