W2 340 heads #579832
01/11/10 06:45 PM
01/11/10 06:45 PM
Dunmore, PA ,
P
plumber425 Offline OP
P
Dunmore, PA ,
I have w2 heads on my 340 Duster & just found out one has 2 cracks in it.. I found a set on e-bay but the casting #'s are different than mine. my # is 3870810 his are 3577634 I called the mopar tec line they never seen this #. and suggested this site anybody know if these are the same as my heads? the pics. look like mine....
Mike
Re: W2 340 heads [Re: plumber425] #579833
01/11/10 06:50 PM
01/11/10 06:50 PM
San Diego
formula S Offline
formula S  Offline
San Diego
sounds like an early set get a hold of RyanJ he can help you http://www.shadydellspeedshop.com/
Re: W2 340 heads [Re: plumber425] #579834
01/11/10 06:56 PM
01/11/10 06:56 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'd hold off on anything that didn't match up. 3870810 casting
spanned several years and are pretty east to find. There were
a few different versions of the same casting. Pictures would
help a lot.
Welcome to Moparts.
Re: W2 340 heads [Re: S/ST 3040] #579835
01/11/10 06:59 PM
01/11/10 06:59 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
here are the pics.. http://cgi.ebay.com/ebaymotors/Mopar-340...sQ5fAccessories
Thanks for the welcome
Mike
Re: W2 340 heads [Re: formula S] #579836
01/11/10 07:02 PM
01/11/10 07:02 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
Thanks I called there just b4 the mopar tec. line I didnt get a call bk. yet
Mike
Re: W2 340 heads [Re: plumber425] #579837
01/11/10 07:19 PM
01/11/10 07:19 PM
S/ST 3040 Offline
S/ST 3040  Offline
here are the pics..
I meant, pictures of your heads.
Re: W2 340 heads [Re: plumber425] #579838
01/11/10 07:36 PM
01/11/10 07:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
Those are early heads(note the single bolt pattern on
the exhaust) also it says ported and polished a bit,
well the exhaust ports look real big
EDIT
those are the race W-2s also not the econo's so if
you have econo heads the stands are different
Re: W2 340 heads [Re: MR_P_BODY] #579839
01/11/10 09:01 PM
01/11/10 09:01 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Those look like the 810 heads, they are the early heads as noted (usually casting dates will be between 1976-1978, the majority were 1977) they are identifiable by the freeze plugs in the ends, they had allot of casting variability and it was common that they cracked, usually because of port work in an area where there was unpredicted core shift (AMHIK).
The later heads that have "W2" cast into the sides under where the spark plug holes, and no freeze plugs in the ends, they are/were cast better. Same basic heads, (respective to Race or Econo) just a better/later casting.
As noted the heads in the auction look EXTENSIVELY ported, those are probably some of the earliest heads made if Petty had them, and likey better than average concerning core shift issues,I'd still be leary about cracks, thins spots, or epoxy filled holes with that set.
Re: W2 340 heads [Re: S/ST 3040] #579840
01/11/10 10:38 PM
01/11/10 10:38 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
here r some pics. I have of my heads.....
http://s136.photobucket.com/albums/q183/plumber425/W2%20340/
71 W2 340 Street/Strip 11.82 115 Mph....
Re: W2 340 heads [Re: plumber425] #579841
01/11/10 10:47 PM
01/11/10 10:47 PM
S/ST 3040 Offline
S/ST 3040  Offline
That's what I would call a "1st Generation" W-2. 77-early 80's.
Freeze plugs are dead give-away. They're around. Keep looking.
I have ONE for R&D.
Post an ad in "SB Parts Wanted"
Re: W2 340 heads [Re: plumber425] #579842
01/11/10 10:47 PM
01/11/10 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah your heads are the same.... but the e-bag heads
have 11/32 valve stems and a larger intake valve...
your exhaust ports dont look to be ported... are they
Re: W2 340 heads [Re: MR_P_BODY] #579843
01/11/10 10:58 PM
01/11/10 10:58 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
Yes mildy ported. cant tell in these pics.. How can u tell e-bay intake valves are bigger?
Re: W2 340 heads [Re: S/ST 3040] #579844
01/11/10 10:59 PM
01/11/10 10:59 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
R&D?
Re: W2 340 heads [Re: plumber425] #579845
01/11/10 11:04 PM
01/11/10 11:04 PM
S/ST 3040 Offline
S/ST 3040  Offline
Research and Development.......you know. Grind holes in, etc.
Here's a post where we discussed those E-bay W-2s briefly. Not the same as your's.
https://board.moparts.org/ubbthreads/show...rue#Post5663318
Re: W2 340 heads [Re: S/ST 3040] #579846
01/11/10 11:32 PM
01/11/10 11:32 PM
Dunmore, PA ,
P
P
Dunmore, PA ,
I dont know if they would work on my motor. my heads have the long valves and I think they should have the short ones I had smith bros. make push rods to fit these valves & if these e-bay heads have short valves they wont work Im going to sell this car so I dont want to get in to deep....
Re: W2 340 heads [Re: plumber425] #579847
01/11/10 11:39 PM
01/11/10 11:39 PM
S/ST 3040 Offline
S/ST 3040  Offline
If your heads have offset rocker shafts and stands, they should have 5.280"-5.300" valves.
Post some pictures of your car and tell us about it.
Street? Strip? What's it run?
Re: W2 340 heads [Re: plumber425] #579848
01/11/10 11:45 PM
01/11/10 11:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It says in the right up(lower on the page) that they
have 11/32 stems and 2.100 intake valves
Re: W2 340 heads [Re: S/ST 3040] #579849
01/12/10 12:07 AM
01/12/10 12:07 AM
Dunmore, PA ,
P
P
Dunmore, PA ,
Street/Srtip when I got the car it was runnin 12.20s with some dialn 12 teens. Freshend the motor & got it to go 11.821 @ 115 MPH WITH the cracked head
Re: W2 340 heads [Re: S/ST 3040] #579850
01/12/10 12:18 AM
01/12/10 12:18 AM
Dunmore, PA ,
P
P
Dunmore, PA ,
Here is a video of a small burnout. I was playin with the pro tree for the first time...Im kinda new at this.. This was a 12.20 pass with the old motor...
http://www.youtube.com/watch?v=TIn8R3G1s4M
Re: W2 340 heads [Re: plumber425] #579851
01/12/10 12:51 AM
01/12/10 12:51 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Gee, thanks!
Mo' Farts
Moderated by "tbagger".
