Re: Disc Brake Conversion Advice
[Re: Sport383]
#579365
01/11/10 03:26 AM
01/11/10 03:26 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Greetings: I need advice or pros and cons for a project. I have a 69 Sport Satellite vert 383/4sp w/ 3:55 8.75 rear. I want to convert it to disc brakes. I now have manual drums all around. I am looking at Wilwoods, SSBC, or MP Brakes. I will be getting a firm feel box with tubular upper 'A' arms also. A PST rebuild kit for the entire front suspension. I want power discs. Any concerns, tips, advice would be appreciated, thanks.
Save the money from the Tubular A-Arms and put that toward some frame connnectors. On a convertible that will be godsed compared to the tubular A-Arm which you will never feel on a mild suspension built flexi flyer convertible.
Just get some factory disk brakes with the 11.75 rotors. You'll need the 11.75 caliper adapters and F/M/J body spindles or 73-76 A-body spindles.
For improve caster adjustment just run offset upper control arm bushing Moog p/n 7103. You should be able to get 3 or more degrees of positive caster with those.
[Re: Sport383]
#579367
01/11/10 02:40 PM
01/11/10 02:40 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Had factory '74 Charger disc brakes (10-3/4" rotors) on my '72 RR for the longest time. Yeah, they were the longer B-body knuckles, but they worked great, stopped great, and never had any problems with ball joints. Upgraged to Andy's Viper caliper setup for the bling factor. The old setup (knuckles, rotors, calipers, brackets) is still wrapped up in plastic in the garage somewhere...
[Re: dirtybee]
#579369
01/11/10 08:18 PM
01/11/10 08:18 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
i agree with above, i swapped to factory '73 to '76 a body discs on my '70 bee and kept it manual. i can't tell it's manual, they work great and they are the small ones, 10 3/4" aprox rotors.
same on my 70 runner,best upgrade,love'em,forget about the tubular uppers
