A body 2" headers, low deck block,stock exhaust port #579286
01/10/10 11:51 PM
01/10/10 11:51 PM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
We are in need of an Abody 2" primary tube dia header(rather not run a fender well header)that works with a low deck block and factory exhaust port location. Anyone have any real world feedback on the choices other than a custom built set? Thanks for any help.
Re: A body 2" headers, low deck block,stock exhaust port [Re: goldmember] #579287
01/10/10 11:58 PM
01/10/10 11:58 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
tti headers
maddog headers
proparts headers (semi fenderwell )
1.39 9.85 - 137 mph
Re: A body 2" headers, low deck block,stock exhaust port [Re: goldmember] #579288
01/11/10 12:06 AM
01/11/10 12:06 AM
I have a 1969 Dart GTS 383 car with Pro Parts older design, they don't fit worth a hoot on the 383 Pro Parts designed them for the RB motors, not the low deck B motors I have bought a set of the Mad Dog low deck headers but I have not put them on yet so I took a set of the Hooker fenderwell headers off that fit real well
Re: A body 2" headers, low deck block,stock exhaust port [Re: goldmember] #579289
01/11/10 12:07 AM
01/11/10 12:07 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use the Pro Parts tubes,same set with 383 and 440.Yes,1 tube on the right side and 2 on the left go thru the fenderwell,but not anything like the Hookers do.My set fits great with the 383 as well as the 440.The 440 gets more room around the starter,but that's about it.
Nautilus Racing-
Re: A body 2" headers, low deck block,stock exhaust port [Re: Chris2581] #579290
01/11/10 01:32 AM
01/11/10 01:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are CPPA 2" chassis headers on the 400 in my boys Dart. TTI took over the design and make the same header from what I hear. These were bought in 1997. Ron
Re: A body 2" headers, low deck block,stock exhaust port [Re: 383man] #579291
01/11/10 08:10 AM
01/11/10 08:10 AM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: A body 2" headers, low deck block,stock exhaust port [Re: Butch] #579292
01/11/10 12:08 PM
01/11/10 12:08 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
TTI 2 in fit a low deck block and factory exhaust port location?
There site seems to show
Big Block 2" Headers
"383/400 B-engines
fits with the following
Cylinder Heads
Must use these heads to run 2" Headers on Low-deck block.
Indy 440SR, Indy 440-1 (Raised-port) cylinder heads
*Edelbrock Victor or Stage 6"
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: A body 2" headers, low deck block,stock exhaust por [Re: megajoltman] #579293
01/11/10 07:37 PM
01/11/10 07:37 PM
Ohio
W
wedgg440 Offline
wedgg440  Offline
W
Ohio
I agree!I have the 2" TTI. headers and you have to use a head with raised exhaust ports.I used the indy sr 's and they fit perfectly.
Re: A body 2" headers, low deck block,stock exhaust por [Re: wedgg440] #579294
01/11/10 11:16 PM
01/11/10 11:16 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Mad Dog's site lists the same header for stock and Edelbrock heads. I tried a set on a 383 with Edelbrock heads and NO GO. I sent them back, had them mod'd a bit, and then ran into more fitment problems once I got further in the install. I ended up using Schumachers, and on a 440 (long story).
Anyways for anyone else planning to run them on Edelbrocks, who may come across this thread, I would make darn sure they updated the design since the first few sets that came out 2-3 years ago.
Re: A body 2" headers, low deck block,stock exhaust por [Re: wedgg440] #579295
01/12/10 12:01 AM
01/12/10 12:01 AM
Gainesville,FL
Gainesville,FL
I was looking for someone that had run the TTI's on a low deck,stock exhaust location head and if the fitment issues were not easy to overcome. Thanks for the feedback.
Re: A body 2" headers, low deck block,stock exhaust por [Re: goldmember] #579296
01/12/10 02:31 PM
01/12/10 02:31 PM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
I got a '70 Dart with a /6 K-member and Schumacher /6 to bigblock conversion engine mounts.
Got a low deck with Eddy heads (stock exhaust location) in it, power steering and a 727 tranny.
My TTI 2" fit very good, only had to put a small dent in one pipe for the power steering box, for the rest no problems.
First i had a 4-speed in it and that was also no problem.
Re: A body 2" headers, low deck block,stock exhaust por [Re: 383duster] #579297
01/12/10 11:43 PM
01/12/10 11:43 PM
Gainesville,FL
Gainesville,FL
Thanks again.
