Page 1 of 4 1 2 3 4
70 E dash seat belt light and bezel #57898
05/08/08 02:23 PM
05/08/08 02:23 PM
NoVa
E
ebodyseast Offline OP
E
NoVa
This seat belt warning light and bezel, seen in pic below - is either 1) commonly missing on most restorations or 2) it just wasn't installed into too many cars - maybe only E conv's were to come through with one or those cars ordered with loaded light packages, of either A01/A04. Some one here should be able to clear the facts as I cannot.
Gran Coupe/SE/leather optioned HTs with overhead console would not require/have one, there is already a warning light in the console, but the convs may have had one.
Can't find it mentioned in the '70 Plymouth FSM or anywhere on the wiring diagram - the only mention of a replacement bulb there for any seat belt indicator is for a four door model Mopar.
Car has SPD of 7/3/70. Anyone else here have one of these in their E Body or seen one in one before? It is fed by the tan accessory feed on dash harness. The dash frame has a hole where this or the 4 spd reverse bezel is mounted.
"Remember Obi-Wan...there is always a bigger fish." ~ Qui Gon Jin
Re: 70 E dash seat belt light and bezel [Re: ebodyseast] #57899
05/08/08 03:07 PM
05/08/08 03:07 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Lemme go snap a photo, and then post some words.
Down to just a blue car now.
Re: 70 E dash seat belt light and bezel [Re: ebodyseast] #57900
05/08/08 03:08 PM
05/08/08 03:08 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Only on non SE/GC cars with deluxe seat belts.
Amazing how an unchallenged lie can become the absolute truth.
Re: 70 E dash seat belt light and bezel [Re: ebodyseast] #57901
05/08/08 03:55 PM
05/08/08 03:55 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Nicholas,
If you have just joined one month ago with little lurking beforehand, let me warn you that there are many knowledgeable people on this site, some of whom are married to their "facts". Sometimes individual's "facts" differ from those of others, and bickering ensues. As a matter of fact, just my observation of this might itself cause bickering. This behavior is not limited to online boards - I spent a fair amount of time two weekends ago listening to someone patiently explaining just how 'wrong" my seat belts were, because he'd never seen anything like them.
Let me divide my comments into personal experience / empirical observation, and hearsay that was represented to me as "fact" by knowledgeable persons.
Personal experience / empirical observations:
I have owned a 1970 Challenger R/T convertible (SPD 9/15/69) since 1979. At the time I purchased it, there was nothing to lead me to believe anyone had tampered with the seat belts. The fender tag was present, but the buildsheet was missing (or perhaps discarded on my watch in Tijuana at an upholstery shop). On the fender tag is the code C15 - Deluxe Restraint System. On the dash is a red light that turns on with the courtesy circuit, and stays lit for a variable amount of time (ranging from as little as 10 to as much as 30 seconds) after the courtesy circuit goes off. The length of delay seems to increase, the longer the courtesy lights were lit. My seat belts are push-button style, with a white band around the perimeter. Although they [the female portion] appear slightly larger than the 71-ish push button style, the MALE portion appears to be the same (and firmly/solidly mates with either style). Attached is a photo with the Deluxe next to a 71-ish sample. You will notice the difference in size, button shape, top embossing, and white perimeter banding.
I have personally seen many other E body convertibles (R/T and otherwise) without this C15 group. It is, in my experience on the planet, a rare item.
Hearsay:
The bezel and mounting stuff is the same as the reverse light, with the exception of the lens.
In rare situations, it can be found on 4-speed cars, in which case the factory punches another hole, and the two lights are side-by-side.
The seat belts can also be found on selected C-bodies (although I have never seen this, and might be willing to buy the whole dang car just to get the rear belts that my car now lacks because of what some foolish kid did back in the 80's [please don't compare this date with my date of acquisition]).
I hope this helps. (You got any belts like mine?)
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57902
05/08/08 05:01 PM
05/08/08 05:01 PM
NoVa
E
E
NoVa
Yeah the info you posted definitely helps, me, and anyone else here interested or for future reference.
It does have seat belts with a white perimeter.
With some searching you'll find those rear seat belts you're wanting, maybe even this year since the fever may be flowing within again.
I'd like to see a pic of the light you have and if mounted to dash if you can also post one.
beepbeep posted an excellent pic of the two lights together.
So - '70 hard top models with C15 option will also have this same light and bezel and style of seat belts. Cool...
Re: 70 E dash seat belt light and bezel [Re: ebodyseast] #57903
05/08/08 05:27 PM
05/08/08 05:27 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I was quite surprised how the chrome showed up in this flash photo. It doesn't seem nearly this thrashed in natural light.
But thrashed it is. This car spent quite a lot of time sitting in the SoCal sun and smog with the top down. To say nothing of the fan blade through the hood. And the times there were three guys standing on the back seat hanging a triple-B.A. And the time when...
(you get the idea)
As for painting all C15-equipped hard tops with the same broad brush stroke, not so fast.
Beepbeep earlier alludes to the intersection of GC/SE models with C15. Perhaps simply the intersection of overhead console [which would already have a seat belt light] with C15. Now we're beyond hearsay, into the land of speculation by your humble poster.
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57904
05/08/08 05:38 PM
05/08/08 05:38 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
In addition to the very knowledgeable Beepbeep, one might expect Randy (1WildRT) to weigh in on this issue, bringing his not insignificant experience to the table. He is probably on a plane coming back from the land of banjos as I post this.
Nevertheless, not unlike the bat symbol shining on the clouds to summon the caped crusader and his boy-wonder, the mere scent of this kind of subject (or perhaps the use of his screen name in vain) will likely draw him to this very thread.
Or not.
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57905
05/08/08 05:39 PM
05/08/08 05:39 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Type of seatbelts did not matter on SE and GC or any Barracuda with overhead consoles.
Again the only time you will find it on a non SE or GC car is with deluxe seat belts.
Re: 70 E dash seat belt light and bezel [Re: beepbeep] #57906
05/08/08 05:43 PM
05/08/08 05:43 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Type of seatbelts did not matter on SE and GC with overhead consoles.
But one might encounter deluxe seat belts in a GC or SE, and if so found, said car would NOT be equipped with the dash seat belt light ('cuz there's already one in the overhead console).
Is this a correct statement?
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57907
05/08/08 05:46 PM
05/08/08 05:46 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Correct.
Re: 70 E dash seat belt light and bezel [Re: beepbeep] #57908
05/08/08 05:47 PM
05/08/08 05:47 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57909
05/08/08 05:50 PM
05/08/08 05:50 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Those type of bezels also were used for tailgate ajar and NOX emissions.
Re: 70 E dash seat belt light and bezel [Re: 68HemiB] #57910
05/08/08 06:06 PM
05/08/08 06:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Or not.
Looks like the subject is well covered..BTW I'm still in the Land of Relative Humidity.....Which you'll have to use your own imagination to decipher...
Re: 70 E dash seat belt light and bezel [Re: 1_WILD_RT] #57911
05/08/08 06:13 PM
05/08/08 06:13 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
nee nee, nee nee, nee nee, nee nee
nee nee, nee nee, nee nee, nee nee...
BATMAN!
Re: 70 E dash seat belt light and bezel [Re: beepbeep] #57912
05/08/08 06:22 PM
05/08/08 06:22 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Here's another picture of one with correct yellow wiring harness
Re: 70 E dash seat belt light and bezel [Re: mccannix] #57913
05/08/08 07:08 PM
05/08/08 07:08 PM
Alabama
BigMoneyLewis Offline
Alabama
That seat belt light was used on 1970 B body cars as well, when you had the C15 deluxe seat belt package. As previously mentioned, it gave you the 71 style seatbelts.
My 70 Charger R/T SE sublime dealer demo car had the deluxe seatbelt package with dash light.
March 18 SPD.
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: 70 E dash seat belt light and bezel [Re: BigMoneyLewis] #57914
05/08/08 08:28 PM
05/08/08 08:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Here's some overlapping and semi-related info from a previous thread regarding dash lights: https://board.moparts.org/ubbthreads/show...t=1#Post4266472
Re: 70 E dash seat belt light and bezel [Re: beepbeep] #57915
05/09/08 12:37 AM
05/09/08 12:37 AM
PA
BS27ROB Offline
BS27ROB  Offline
PA
Joe, I think we've talked about this before but my Cuda BS27ROB280XXX SPD 3-18-70 has standard belts, but has the light. The broadcast sheet is coded 3 under L73 S/BELT UNF LAMP. I've never figured out why it got coded for it, but it's definitely original. Anyone have any ideas?
Cy
Re: 70 E dash seat belt light and bezel [Re: BS27ROB] #57916
05/09/08 02:35 AM
05/09/08 02:35 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Cy
Your car has leather interior correct?
Re: 70 E dash seat belt light and bezel [Re: beepbeep] #57917
05/09/08 07:22 AM
05/09/08 07:22 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
B Beep: There was a 70 Barracuda Gran Coupe convertible 383+4 at Spring Fling a few years back. Burnt Orange with burnt orange interior with the C15 option. It had burnt orange belts with the seat belt light. The C15 belts were available on A,B,C,E and Y body cars, but the belts themselves are not accuratly interchangable between the body types. They have different part numbers, belt lengths, etc.
Page 1 of 4 1 2 3 4
