How can you be sure of a converters stall ? #578881
01/10/10 05:48 PM
01/10/10 05:48 PM
Cleveland
sunroofgtx Offline OP
Cleveland
Here is the key ,....when it's out of the trans? Do I need to send it to a shop, and have them split it?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: How can you be sure of a converters stall ? [Re: sunroofgtx] #578882
01/10/10 06:57 PM
01/10/10 06:57 PM
florida
74fldart Offline
74fldart  Offline
florida
A convertor factory can test it out without cutting it open. I dont know what they would charge to do it.
Re: How can you be sure of a converters stall ? [Re: 74fldart] #578883
01/10/10 07:54 PM
01/10/10 07:54 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Rick Sigman 440-232-9677 he does converters for Charlie Kuchenbecker.
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: How can you be sure of a converters stall ? [Re: sunroofgtx] #578884
01/10/10 07:58 PM
01/10/10 07:58 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
hay rick i wonder if abruzzi would test it for you.
Re: How can you be sure of a converters stall ? [Re: blownzoom440] #578885
01/10/10 08:27 PM
01/10/10 08:27 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
It'll also vary from engine too engine a bit, so you may want to make sure they can test it behind something close to what you have or building.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: How can you be sure of a converters stall ? [Re: joedust451] #578886
01/10/10 11:31 PM
01/10/10 11:31 PM
Cleveland
Cleveland
Thanks guys. I had it made by Carl Byrd, near Norwalk Raceway, around 1996. I forgot what specs I had him build it at.. Thanks,.He passed away.
Re: How can you be sure of a converters stall ? [Re: sunroofgtx] #578887
01/11/10 05:41 AM
01/11/10 05:41 AM
ELYRIA,OH
ELYRIA,OH
rick there may be some ID #'s stamped on it tohelp determine what it is nade to do.is there some1 to look at his records?
