School me on slapstick operation #578411
01/10/10 12:05 PM
01/10/10 12:05 PM
BDW Online content OP
BDW  Online Content OP
I'm putting my shifter back in after a carpet install and the shifter operation doesn't seem right.
When I put the shifter in reverse in can be pulled back to neutral without pushing the button, this is normal.
Now in neutral in can be pulled back again to drive (without pushing the button), still ok.
My problem is once it's in drive with the above process it can be pushed back in neutral without pushing the button (doesn't seem right)?
Only way it will not go from D to N (unless button is pushed) is if I bring it past D to 2 or 1 then push forward (slapstick).
Is this right? Never noticed this before.
Re: School me on slapstick operation [Re: BDW] #578412
01/10/10 12:13 PM
01/10/10 12:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
thats the way they work
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: School me on slapstick operation [Re: aarcuda] #578413
01/10/10 01:37 PM
01/10/10 01:37 PM
Thx,
After looking at the mechanism closely I guess it is the way it works.
Just seems strange that you could go from D to N without pushing the button. Never noticed that before.
Re: School me on slapstick operation [Re: BDW] #578414
01/10/10 01:47 PM
01/10/10 01:47 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
Yep, that's how a slapstik works. The only way to lock it in Drive is to engage 1st or 2nd gear first...
Re: School me on slapstick operation [Re: BDW] #578415
01/10/10 01:50 PM
01/10/10 01:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thats a rachet system,
-from 1 up to D... then from D to N need to press button, because will be logical you are at high speeds on upshifting procedure, making dangerous to jump accidentally to N
-On normal driving operation, being you beging at D, you can shift from D to N without press button, since rachet system hasn't been engaged
-From parking and Reverse button need to be pressed anytime to any new location.
EDITING... FROM REVERSE TO NEUTRAL YOU DON'T NEED TO PRESS BUTTON, but need to when getting back to reverse... dunno if I'm missing something else
Re: School me on slapstick operation [Re: NachoRT74] #578416
01/10/10 09:34 PM
01/10/10 09:34 PM
Thx again for the info, makes sense.
I guess I never noticed this since I have a reverse manual valve body and always start from low.
Re: School me on slapstick operation [Re: BDW] #578417
01/11/10 12:35 PM
01/11/10 12:35 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Column shift works the same way.
