Re: Is a Trans brake like a cltch for a automatic?
[Re: mark7171]
#578103
01/10/10 12:13 AM
01/10/10 12:13 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Is a trans brake like a clutch pedal for a automatic trans?
Have some questions as to if they are the same as a Neutral dropping , and do you still require a stall speeed?
Not the same as a neutral drop. The engine will only rev as high as the stall speed of the converter. The transmission is still in gear with the TB engaged.
[Re: BobR]
#578104
01/10/10 12:27 AM
01/10/10 12:27 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
It pretty much applies reverse and low at the same time. It does this with trapped fluid pressure, when you let off the button it simply releases the reverse gear. It doesnt shock the bands, gears or clutches too bad cause they are already applied.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#578105
01/10/10 12:45 AM
01/10/10 12:45 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Much nicer than a clutch and a whole lot less work than a Clutchflite.Those were very violent.Worked well but part killers.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#578106
01/10/10 03:24 AM
01/10/10 03:24 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The best way to understand it initially, is that its basically just as it states... A brake inside the transmission. While you're at the line, instead of braking with the wheels, the transmission holds itself. you're still up against the stall speed of the converter.
[Re: StealthWedge67]
#578107
01/10/10 11:38 AM
01/10/10 11:38 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
just like mentioned above..it enguages first gear and reverse... which locks it in place..everything is loaded inside the trans..sans the ringear you could consider it like chaining your car to a tree..puting it in first gear and pulling the chain.....the chain holds you there... if you drop the chain and the car launches....its that basic pricipal......
you can put what ever amount of rpm you want at the stage... its only based/limited by your converters stall rpm..
if you have a fast car..have your head/neck ready it can suprise you.. chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#578108
01/10/10 12:53 PM
01/10/10 12:53 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
More fun than foot braking but you'll find the next weak link in drive train. but thats racing . dr
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
