Is a Trans brake like a cltch for a automatic? #578101
01/09/10 11:45 PM
01/09/10 11:45 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
Is a trans brake like a clutch pedal for a automatic trans?
Have some questions as to if they are the same as a Neutral dropping , and do you still require a stall speeed?
Re: Is a Trans brake like a cltch for a automatic? [Re: mark7171] #578102
01/09/10 11:56 PM
01/09/10 11:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It would be sorta like dumping the clutch... but only
if you have a nice stall in the converter
Re: Is a Trans brake like a cltch for a automatic? [Re: mark7171] #578103
01/10/10 12:13 AM
01/10/10 12:13 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Not the same as a neutral drop. The engine will only rev as high as the stall speed of the converter. The transmission is still in gear with the TB engaged.
Re: Is a Trans brake like a cltch for a automatic? [Re: BobR] #578104
01/10/10 12:27 AM
01/10/10 12:27 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It pretty much applies reverse and low at the same time. It does this with trapped fluid pressure, when you let off the button it simply releases the reverse gear. It doesnt shock the bands, gears or clutches too bad cause they are already applied.
Re: Is a Trans brake like a cltch for a automatic? [Re: Bob_Coomer] #578105
01/10/10 12:45 AM
01/10/10 12:45 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Much nicer than a clutch and a whole lot less work than a Clutchflite.Those were very violent.Worked well but part killers.
Leave the gun.......take the Cannoli's....Mike
Re: Is a Trans brake like a cltch for a automatic? [Re: mike s] #578106
01/10/10 03:24 AM
01/10/10 03:24 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The best way to understand it initially, is that its basically just as it states... A brake inside the transmission. While you're at the line, instead of braking with the wheels, the transmission holds itself. you're still up against the stall speed of the converter.
Re: Is a Trans brake like a cltch for a automatic? [Re: StealthWedge67] #578107
01/10/10 11:38 AM
01/10/10 11:38 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
just like mentioned above..it enguages first gear and reverse...
which locks it in place..everything is loaded inside the trans..sans the ringear
you could consider it like chaining your car to a tree..puting it in first gear and pulling the chain.....the chain holds you there...
if you drop the chain and the car launches....its that basic pricipal......
you can put what ever amount of rpm you want at the stage...
its only based/limited by your converters stall rpm..
if you have a fast car..have your head/neck ready
it can suprise you..
chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Is a Trans brake like a cltch for a automatic? [Re: cheapstreetdustr] #578108
01/10/10 12:53 PM
01/10/10 12:53 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
More fun than foot braking but you'll find the next weak link in drive train.
but thats racing .
dr
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
