Re: 360 w/ 4.00 stroke?
[Re: 340_Dart]
#577888
01/09/10 08:32 PM
01/09/10 08:32 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
FWIW, i wouldn't run stock rods in that motor if you ever plan on running it hard
H beams can be had cheaper than getting the stock rods resized....and are much stronger.
You looking at cast or forged cranks?
[Re: 68gtxsurvivor]
#577890
01/09/10 08:53 PM
01/09/10 08:53 PM
Quicktree
Its going in my 4x4 truck, no high rpm's or drag strip time just a mild motor.
I still wouldn't use a stock rod
[Re: Quicktree]
#577891
01/10/10 10:58 AM
01/10/10 10:58 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Unless you have them magged , checked for straightness , polish the beams , shot peened , re-size and new ( good ) bolts , stock rods are marginal pieces. And if you do the math , aftermarket rods will come in around 200.00 a set cheaper. Never used to be that way ............ only because there never was the amount of aftermarket parts available. This is one of the few examples of where the good old days weren't all that good.
[Re: topside]
#577893
01/10/10 12:44 PM
01/10/10 12:44 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
My 410 360 .040 cast crank I upgraded to forged pistons in the kit .OHIO CRANK kit 7years ago .Other kits available . Don't use the old stuff new rods ,arps bolts get the crank internally balanced if using cast crank Mallory will cost . Don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: ademon]
#577895
01/10/10 01:29 PM
01/10/10 01:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If it truly is a low RPM 4x4 (not all 4x4 are low RPM motors) get a cast SCAT crank and SCAT I beam rods they are cheaper and better than getting your stock rods done and require no block grinding like a stock rod. Don't bother with internally balancing unless it is a high reving motor in that case start with a forged crank.
