360 w/ 4.00 stroke? #577885
01/09/10 07:55 PM
01/09/10 07:55 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
someone school me on the 4.00 strok crank for a 360, do i use my stock rods and pistons?
Re: 360 w/ 4.00 stroke? [Re: 68gtxsurvivor] #577886
01/09/10 07:56 PM
01/09/10 07:56 PM
Stockholm,SWEDEN
The Nutcracker Offline
Stockholm,SWEDEN
Stock rods, custom pistons!
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: 360 w/ 4.00 stroke? [Re: The Nutcracker] #577887
01/09/10 08:26 PM
01/09/10 08:26 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
there are off shelf piston offerings for that motor made by nearly every major piston maker...
FWIW, i wouldn't run stock rods in that motor if you ever plan on running it hard
Re: 360 w/ 4.00 stroke? [Re: 340_Dart] #577888
01/09/10 08:32 PM
01/09/10 08:32 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
H beams can be had cheaper than getting the stock rods resized....and are much stronger.
You looking at cast or forged cranks?
Re: 360 w/ 4.00 stroke? [Re: HemiDave] #577889
01/09/10 08:51 PM
01/09/10 08:51 PM
Lexington,VA
Lexington,VA
Its going in my 4x4 truck, no high rpm's or drag strip time just a mild motor.
Re: 360 w/ 4.00 stroke? [Re: 68gtxsurvivor] #577890
01/09/10 08:53 PM
01/09/10 08:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I still wouldn't use a stock rod
Re: 360 w/ 4.00 stroke? [Re: Quicktree] #577891
01/10/10 10:58 AM
01/10/10 10:58 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Unless you have them magged , checked for straightness , polish the beams , shot peened , re-size and new ( good ) bolts , stock rods are marginal pieces.
And if you do the math , aftermarket rods will come in around 200.00 a set cheaper.
Never used to be that way ............ only because there never was the amount of aftermarket parts available.
This is one of the few examples of where the good old days weren't all that good.
Re: 360 w/ 4.00 stroke? [Re: tubtar] #577892
01/10/10 12:36 PM
01/10/10 12:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Used 340 rods in my 406, street motor, no problem with them.
Cast crank, did require some mallory to balance. Don't buy the MP cast pistons though; MP advertised them for this combo, but they're for Chevy rods (!) and require machining to fit Mopar rods.
Re: 360 w/ 4.00 stroke? [Re: topside] #577893
01/10/10 12:44 PM
01/10/10 12:44 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
My 410 360 .040 cast crank I upgraded to forged pistons in the kit .OHIO CRANK kit 7years ago .Other kits available .
Don't use the old stuff new rods ,arps bolts get the crank internally balanced if using cast crank Mallory will cost .
Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: 360 w/ 4.00 stroke? [Re: topside] #577894
01/10/10 12:45 PM
01/10/10 12:45 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Stock 340 rods with just good bolts are plenty strong, tons of guys running them in in 400 to 500hp range. That said i would go with good aftermarket rods cheaper & stronger in the long run.
Re: 360 w/ 4.00 stroke? [Re: ademon] #577895
01/10/10 01:29 PM
01/10/10 01:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If it truly is a low RPM 4x4 (not all 4x4 are low RPM motors) get a cast SCAT crank and SCAT I beam rods they are cheaper and better than getting your stock rods done and require no block grinding like a stock rod. Don't bother with internally balancing unless it is a high reving motor in that case start with a forged crank.
