HELP Whining noise from new gear set in rear end #57773
05/04/08 05:23 PM
05/04/08 05:23 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I had a Mopar master mechanic install a new 4.10 gear set and SG in an 8 1/4. The rear end has the proper gear oil and the SG additive. Drove the car yesterday and it sounds normal when under acceleration but when you back off the gas it makes a loud whining sound. Will this go away in time, normal, or should I have the mechanic check it out?
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57774
05/04/08 05:24 PM
05/04/08 05:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It most likely is set up wrong. It wont go away.
Re: HELP Whining noise from new gear set in rear end [Re: NITROUSN] #57775
05/04/08 09:40 PM
05/04/08 09:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Probably in the set-up, but to tell you the truth I never had great success in setting up 4.10 or higher gears in 8.75's that were "quiet". Seemed to always have a noise at some rpm or another. I just set them up so the drive contact was centered and not too deep and let em eat. At least they lasted.
Re: HELP Whining noise from new gear set in rear end [Re: J_BODY] #57776
05/04/08 09:47 PM
05/04/08 09:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I agree with Jay. The deeper the gear the more prone to noise.
I got a se t of 4.56's that you can hear over the headers. I am the second owner, and both of us had them professionally set up but at different shops. granted when I got them the pattern was set so curing the singing was not an option. Don't get hot and work fine for what they are used for.
Think that you are noisy - listen to some of teh 18 wheelers go down the highway.
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57777
05/05/08 01:42 AM
05/05/08 01:42 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Probably set up wrong. I'm not bashing installer; just saying I'd try to get it fixed before it ruins gear.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57778
05/05/08 06:43 AM
05/05/08 06:43 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
If he`s anything like the last "mopar master mechanic" at the dealership who worked on my truck I wouldn`t let him work on my wheelbarrow.
Your gears are set up wrong.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: HELP Whining noise from new gear set in rear end [Re: gamagoat6x6] #57779
05/05/08 10:39 AM
05/05/08 10:39 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
First thing to check is the pinion nut and make sure it is tight and that there is no slop in the bearings. The pinion will try to pull back into the case on decelleration altering the setting If all is well the gears are set to shallow.
I 've run up to 5:13's in 8-3/4's with no noise issues. If The gears are set up wrong they are possibly already torched. They wear a pattern very quickly. After running them, Re-setting them may quiet them down but there will most likley be some noise left
Tim
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57780
05/05/08 12:42 PM
05/05/08 12:42 PM
crlush Offline
crlush  Offline
wrong setup!!!!
Re: HELP Whining noise from new gear set in rear end [Re: crlush] #57781
05/05/08 01:50 PM
05/05/08 01:50 PM
florida
74fldart Offline
74fldart  Offline
florida
the backlash is off when you have the whining on deceleration. as soon as possible take it back. i took my rear apart for a suregrip rebuild and i only took out the ring gear and i didnt get it back right and had just what you r describing, so i took the chunk (8/3/4 ) to a buddy who set it up right. and no more whining when slowing down.
Re: HELP Whining noise from new gear set in rear end [Re: 74fldart] #57782
05/05/08 02:51 PM
05/05/08 02:51 PM
Houma, Louisiana
Houma, Louisiana
Mine is an 8 1/4" differential, can the adjustment be made with car on lift?
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57783
05/05/08 03:37 PM
05/05/08 03:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57784
05/05/08 04:37 PM
05/05/08 04:37 PM
PNW
Danan Offline
Danan  Offline
PNW
8 1/4 with 4.10s...very gutsy. What brand gears are they? I've never had a set of richmond gears that didn't whine a little, but have had zero issues with spicer, strange/us gear, or yukons..
Re: HELP Whining noise from new gear set in rear end [Re: Danan] #57785
05/05/08 06:36 PM
05/05/08 06:36 PM
Houma, Louisiana
Houma, Louisiana
Motive gears and spicer SG. Dr Diff said Motive was a good gear set. I will get the mechanic to check it out and see if everything is in specs. I also have a Duster with 400 HP on the dyno and an 8 1/4 with 3.91 and SG with a set of MT street radials. No problems!!!!! Will try for 450 HP on a stroker for the Dart but will likely switch to an 8 3/4, but that is down the road.
Re: HELP Whining noise from new gear set in rear end [Re: twister360] #57786
05/05/08 07:32 PM
05/05/08 07:32 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
I'm having the same problems with an 8.75" 4.11 SG setup. It was recommended to me by member dvw that I do this since I've got the pig out. Haven't done it yet though, too much school...
Howling on decell only indicates a problem on the coast side pattern. Either its set up wrong now or was set up wrong previously. Gear sets are lapped at the factory. Changing the point at which they run can try to wear a new pattern. You can tell by running a pattern check. Load the ring gear by using a pry bar between the ring gear and case,then rotate in both directions. If the marking compond is removed from the outer edges of the concave side of the teeth,it will make noise on decell. If the pinion depth and backlash are correct sometimes you can make slight adjustments to help. You would be amazed how much .002-.003 backlash can make. At worst either run it or you will have to replace the gear set. Howling seldom causes a problem if its not severe.
Doug
Re: HELP Whining noise from new gear set in rear end [Re: MarkZ] #57787
05/20/08 09:46 AM
05/20/08 09:46 AM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
What causes noise under steady cruising...don't know id it makes noise under acceleration...just notice it when I'm cruising at steady speed. Have had two different 3.55 setups and both have done same thing.
Re: HELP Whining noise from new gear set in rear end [Re: gamagoat6x6] #57788
05/20/08 10:17 AM
05/20/08 10:17 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Exactly. The "master mechanic" at the Dodge dealership set the rear end in my truck up so well that he forgot to pour in some additive. Had to take my truck back in and leave it another day to find out why it was chattering through corners.
Re: HELP Whining noise from new gear set in rear end [Re: dwbiggs] #57789
05/20/08 12:47 PM
05/20/08 12:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What your talking about is a float condition, neither loaded or unloaded. It usually occurs around 45 mph give or take. There is one more possibility that we haven't discussed. If the pinion bore was machined low,high or at a angle. this would cause the lapped in pattern of the gear set to run in a different spot even with proper backlash and pinion depth. there is no repair for this without carrier replacement.
Doug
