E-body torque shaft length/width #577652
01/09/10 05:44 PM
01/09/10 05:44 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
Does anyone know the length/width of an E-body torque shaft...1970 w/big block and an aluminum 513 bellhousing.
Jason
Re: E-body torque shaft length/width [Re: JRepucci] #577653
01/09/10 10:36 PM
01/09/10 10:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Cuda, Challenger? ...8 3/4, DANA? all different lengths because of wheelbase and axle choice.....bellhousing doesn't matter
Re: E-body torque shaft length/width [Re: JRepucci] #577654
01/09/10 11:19 PM
01/09/10 11:19 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
They are 9" long. Sm block is also 9". The difference between the 2 is where the bellhousing end arm is welded. Either one will work with a BB as long as you have the correct adjuster rod.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: E-body torque shaft length/width [Re: Dan Brewer] #577655
01/09/10 11:56 PM
01/09/10 11:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I thought the OP wanted Driveshadt length, not Z bar info....oh well
Re: E-body torque shaft length/width [Re: DAYCLONA] #577656
01/10/10 03:31 AM
01/10/10 03:31 AM
JRepucci Offline OP
JRepucci  Offline OP
Thanks for the help.
