Re: Dyno test comparing Torker and Performer RPM for 383?
[Re: 71Chip]
#577573
01/09/10 04:11 PM
01/09/10 04:11 PM
Posts: 1,458 oklahoma
forphorty
oklahoma
[Re: mark7171]
#577577
01/14/10 03:13 AM
01/14/10 03:13 AM
DaytonaTurbo
Manitoba, Canada
All those tests are around 10 hp/lbs apart. Not realistic to me.
So what, you think they faked the results? If the results are close, it does show on a stockish 383 that the manifold isn't the bottleneck. On part 2 where they bolt on the cnc ported aftermarket heads, the results do change a good bit. Even then, it's not an extreme, rpm screamer of a build.
