Best performance exhaust manifold for smallblock
#577485
01/09/10 02:51 PM
01/09/10 02:51 PM
Posts: 41 Denmark, Aeroe
Moparbil
Denmark, Aeroe
Stock 340HP manifold vs. shorty headers What is best for at street car. Can the aftermarket shorty headers match the 340 HP Going for one of these two, tried of long headers low clearance to ground.
Re: Best performance exhaust manifold for smallblock
[Re: Moparbil]
#577486
01/09/10 04:29 PM
01/09/10 04:29 PM
RapidRobert
the shorties would flow better but make sure they'll fit your app and or be prepared to rework one or more pri tubes. 340 HP's are 2&1/4" outlet and the drivers side one is somewhat restricted from the mandated bends & I'd assume the collector on the header is 2&1/2" or 3".
[Re: Moparbil]
#577489
01/09/10 07:15 PM
01/09/10 07:15 PM
Posts: 5,895 Florida
Locomotion
Here is a Mopar Muscle Magazine test of a variety of OEM manifolds and assorted headers.
Exhaust dyno tests.
[Re: Neil]
#577492
01/09/10 08:13 PM
01/09/10 08:13 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
That is a very tame engine that isn't moving a whole lot of air. Once you get into the 1.25 - 1.5+ HP per cubic inch range cast iron manifolds will really start to kill power.
I'd like to see that engine re-tested with a larger camshaft.
That's over 425 HP.
I would think a 360 cid with 9.5:1 compression, CompXE 268 cam, 1.88 heads, RPM dual plane, would be under 400 HP???
[Re: Scott Carl]
#577494
01/09/10 08:18 PM
01/09/10 08:18 PM
autoxcuda
So Cal
I heard stock Magnum manifolds perform well. I plan on running them on my 318 build. The ones I have are # 53010188 and 53010187. I know there are a couple other part numbers depending on the application but mine came off a Dakota IIRC.
I thought there was never a magnum left side manifold that would clear the driver side steering on an older RWD mopar.
[Re: autoxcuda]
#577495
01/09/10 08:23 PM
01/09/10 08:23 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I haven't had them on yet but just holding them in the general area and eyballing I think they'll work in my Challenger. Hope so anyway...
[Re: autoxcuda]
#577496
01/09/10 08:41 PM
01/09/10 08:41 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
That's over 425 HP.
[Re: BSB67]
#577497
01/09/10 08:46 PM
01/09/10 08:46 PM
autoxcuda
So Cal
That's over 425 HP.
So....
360 cubic inches times 1.25 HP/CID equals 450 HP ?? Or am I figuring something wrong??
[Re: autoxcuda]
#577499
01/09/10 08:59 PM
01/09/10 08:59 PM
Posts: 20,742 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
That's over 425 HP.
So....
What I meant to say is that particular test engine is very mild (camshaft is to blame) so it didn't respond very much to the headers.
If you were to perform the same testing on a 1.25 and up hp per cubic inch engine the results would start to favor the headers a lot more.
[Re: Neil]
#577501
01/09/10 09:14 PM
01/09/10 09:14 PM
autoxcuda
So Cal
I understand that it's a mild engine and won't responds to headers much. But from the numbers you gave, you won't see much gain unless you have a well over 400 HP motor.
Would your typical street 360 with something like a Comp XE268 cam see much gain from headers?
[Re: Scott Carl]
#577503
01/09/10 10:40 PM
01/09/10 10:40 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
The ones to get are 53006617(driver's side) and 53006618(passenger's side) which came on 1992 and early 1993 Dakotas, and are larger than later manifolds. The 1992 manifolds are 2 1/8" inside diameter, and the later ones are 1 7/8" inside diameter. See the attached photo showing an early Dak manifold on top vs. a later one.
[Re: Moparbil]
#577504
01/09/10 10:59 PM
01/09/10 10:59 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Last Spring I swapped out my 70HP manifolds for the TTi's on my combo below (guestimate of 370hp). I noticed right off that the main gain was the extra torque off idle and the second gain that I found was that with the HP manifolds at 60mph I was getting a WOT flash to 3500rpms and with the headers I am now getting 3700rpms at the same 60mph. That is about a 6% flash gain at 60mph which on a guestimated 370hp, that 6% is 23hp. I do not have any dyno or track numbers, just seat of the pants.
Note: The TTi's have excellent ground clearance.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
