Best performance exhaust manifold for smallblock #577485
01/09/10 02:51 PM
01/09/10 02:51 PM
Denmark, Aeroe
Moparbil Offline OP
Moparbil  Offline OP
Denmark, Aeroe
Stock 340HP manifold vs. shorty headers
What is best for at street car.
Can the aftermarket shorty headers match the 340 HP
Going for one of these two, tried of long headers low clearance to ground.
Re: Best performance exhaust manifold for smallblock [Re: Moparbil] #577486
01/09/10 04:29 PM
01/09/10 04:29 PM
the shorties would flow better but make sure they'll fit your app and or be prepared to rework one or more pri tubes. 340 HP's are 2&1/4" outlet and the drivers side one is somewhat restricted from the mandated bends & I'd assume the collector on the header is 2&1/2" or 3".
Re: Best performance exhaust manifold for smallblock [Re: Moparbil] #577487
01/09/10 05:05 PM
01/09/10 05:05 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
If you have the $$, TTI's are the way to go.
Re: Best performance exhaust manifold for smallblock [Re: JonC] #577488
01/09/10 06:26 PM
01/09/10 06:26 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
What shorty or tri Y headers are you looking at??
I've heard the Headman shorties in a A-body don't fit well at all. I don't know if they fit B/E bodies any better.
Schmacher made some big block A-body tri Y headers. Those are nice. But only for that application.
Re: Best performance exhaust manifold for smallblock [Re: Moparbil] #577489
01/09/10 07:15 PM
01/09/10 07:15 PM
Locomotion Offline
Locomotion  Offline
Here is a Mopar Muscle Magazine test of a variety of OEM manifolds and assorted headers.
Exhaust dyno tests.
Re: Best performance exhaust manifold for smallblock [Re: Locomotion] #577490
01/09/10 07:32 PM
01/09/10 07:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I find it pretty amazing that they only found 8-10HP/10-15 TQ going from stock 340 manifolds to full buggie TTi's.
Re: Best performance exhaust manifold for smallblock [Re: ScottSmith_Harms] #577491
01/09/10 07:51 PM
01/09/10 07:51 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
That is a very tame engine that isn't moving a whole lot of air. Once you get into the 1.25 - 1.5+ HP per cubic inch range cast iron manifolds will really start to kill power.
I'd like to see that engine re-tested with a larger camshaft.
Re: Best performance exhaust manifold for smallblock [Re: Neil] #577492
01/09/10 08:13 PM
01/09/10 08:13 PM
So Cal
So Cal
That's over 425 HP.
I would think a 360 cid with 9.5:1 compression, CompXE 268 cam, 1.88 heads, RPM dual plane, would be under 400 HP???
Re: Best performance exhaust manifold for smallblock [Re: Neil] #577493
01/09/10 08:15 PM
01/09/10 08:15 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I heard stock Magnum manifolds perform well. I plan on running them on my 318 build. The ones I have are # 53010188 and 53010187. I know there are a couple other part numbers depending on the application but mine came off a Dakota IIRC.
Re: Best performance exhaust manifold for smallblock [Re: Scott Carl] #577494
01/09/10 08:18 PM
01/09/10 08:18 PM
So Cal
So Cal
I thought there was never a magnum left side manifold that would clear the driver side steering on an older RWD mopar.
Re: Best performance exhaust manifold for smallblock [Re: autoxcuda] #577495
01/09/10 08:23 PM
01/09/10 08:23 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I haven't had them on yet but just holding them in the general area and eyballing I think they'll work in my Challenger. Hope so anyway...
Re: Best performance exhaust manifold for smallblock [Re: autoxcuda] #577496
01/09/10 08:41 PM
01/09/10 08:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That's over 425 HP.
Re: Best performance exhaust manifold for smallblock [Re: BSB67] #577497
01/09/10 08:46 PM
01/09/10 08:46 PM
So Cal
So Cal
That's over 425 HP.
So....
360 cubic inches times 1.25 HP/CID equals 450 HP ?? Or am I figuring something wrong??
Re: Best performance exhaust manifold for smallblock [Re: BSB67] #577498
01/09/10 08:47 PM
01/09/10 08:47 PM
fullmetaljacket Offline
Man, you put that Charger on a fair diet and tool up on the converter and gear and you got a good low 11 flat piece.
Re: Best performance exhaust manifold for smallblock [Re: autoxcuda] #577499
01/09/10 08:59 PM
01/09/10 08:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
That's over 425 HP.
So....
What I meant to say is that particular test engine is very mild (camshaft is to blame) so it didn't respond very much to the headers.
If you were to perform the same testing on a 1.25 and up hp per cubic inch engine the results would start to favor the headers a lot more.
Re: Best performance exhaust manifold for smallblock [Re: Moparbil] #577500
01/09/10 09:08 PM
01/09/10 09:08 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I love my A body TTIs. I was running 68 340 manifolds and these fit better and feel great.
Re: Best performance exhaust manifold for smallblock [Re: Neil] #577501
01/09/10 09:14 PM
01/09/10 09:14 PM
So Cal
So Cal
I understand that it's a mild engine and won't responds to headers much. But from the numbers you gave, you won't see much gain unless you have a well over 400 HP motor.
Would your typical street 360 with something like a Comp XE268 cam see much gain from headers?
Re: Best performance exhaust manifold for smallblock [Re: autoxcuda] #577502
01/09/10 09:27 PM
01/09/10 09:27 PM
Locomotion Offline
Locomotion  Offline
Yes, it should. As the dyno test shows, every step that provided a better flowing exhaust system helped. To optimize it, it would help to try different carb settings - jets, squirters, etc.
Re: Best performance exhaust manifold for smallblock [Re: Scott Carl] #577503
01/09/10 10:40 PM
01/09/10 10:40 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
The ones to get are 53006617(driver's side) and 53006618(passenger's side) which came on 1992 and early 1993 Dakotas, and are larger than later manifolds. The 1992 manifolds are 2 1/8" inside diameter, and the later ones are 1 7/8" inside diameter. See the attached photo showing an early Dak manifold on top vs. a later one.
Re: Best performance exhaust manifold for smallblock [Re: Moparbil] #577504
01/09/10 10:59 PM
01/09/10 10:59 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Last Spring I swapped out my 70HP manifolds for the TTi's on my combo below (guestimate of 370hp).
I noticed right off that the main gain was the extra torque off idle and the second gain that I found was that with the HP manifolds at 60mph I was getting a WOT flash to 3500rpms and with the headers I am now getting 3700rpms at the same 60mph. That is about a 6% flash gain at 60mph which on a guestimated 370hp, that 6% is 23hp.
I do not have any dyno or track numbers, just seat of the pants.
Note: The TTi's have excellent ground clearance.
