440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs
#577040
01/08/10 11:32 PM
01/08/10 11:32 PM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
I have a 70 Challenger R/T 440 4bbl that I will be changing over to a six pack soon.
What is the correct order for the fuel line parts?
fuel tank, fuel lines, fuel filter, fuel pump, fuel vapor separator, carburetors
Thanks, Rob
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs
[Re: Rob440Magnum]
#577043
01/09/10 09:18 AM
01/09/10 09:18 AM
Posts: 2,379 White Plains, NY
VCODE
White Plains, NY
Rob, No filter before the pump from the factory. The separator is your filter Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: Rob440Magnum]
#577045
01/09/10 10:30 AM
01/09/10 10:30 AM
Posts: 387 n/w, PA
demonH1B
n/w, PA
Unless you would be assembling this for show, which you aren't or you wouldn't be changing intakes, I have installed filters before the pump as you indicated in your first post. I have never taken apart a vapor seperator but I think it's just a screen filter. The filter ahead of the pump will protect the pump as well as the seperator & carbs. The trucks just prior to f.i. had the filter before the pump.
[Re: screamindriver]
#577047
01/09/10 03:19 PM
01/09/10 03:19 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
It's all about filtering vs restriction...Technically the first factory filter could be the sending unit sock in the tank...But if you're not using one or are unsure if it's there...The easy way out{as already stated} would be to add a filter at the rubber hose between the hard line and the fuel pump..Probably the worst place for the pump itself for performance but considering the rest is all hard line.. .. All you can do is get a good filter with the least amount of restriction...
I have a brand new sending unit and fuel tank. Should I remove the fuel filter before the fuel pump and just use the fuel vapor separator after the pump?
Thanks, Rob
[Re: Rob440Magnum]
#577049
01/09/10 09:01 PM
01/09/10 09:01 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Rob, I'd leave the fuel filter before the pump if you're going to add everything new...I do that when everything is replaced and I've caught some junk that would have ended up in the vapor separator...You'd think with all parts being new that everything is clean but small amounts of dirt, rubber,plating etc... can be initially caught...After a few miles of running you can easily change out the filter with a straight run of hose if you want...That's my ....
