trans cooler lines with headers #576478
01/08/10 06:05 AM
01/08/10 06:05 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
want to replace the the lines,they are all bent and spliced.how hard to do with tti headers on small block a body?will it be possible to snake them through or will headers have to come off?
Re: trans cooler lines with headers [Re: mcmopars] #576479
01/08/10 08:22 AM
01/08/10 08:22 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
I have this same combo, (A) cuda SB TTI, went from front to back, I did however happen to have the radiator out at the time, but i think you should still be able to do it, come up under the front of the car, mine are SS's from fine lines i believe, fit great with minor tweaks for clearance along side header tubs.
Re: trans cooler lines with headers [Re: Lew] #576480
01/08/10 08:29 AM
01/08/10 08:29 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Are you guys using the hard lines specifically for the headers or are you using stock bent lines?
I am just curious because when I added the TTi's to my 340 Challenger, I used my original steel lines on the radiator and at the tranny but I had to cut the middle 16" or so out of each one and use rubber "tranny cooler" lines to reroute without touching the headers or the steering link. I would love to go back to using all steel but the rubber is working just fine.
Re: trans cooler lines with headers [Re: YO7_A66] #576481
01/08/10 08:53 AM
01/08/10 08:53 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Mine are hard all the way, they were not specified for headers when purchased if i recall correctly, like i said, some very minor clearance tweaks, fit great!
Re: trans cooler lines with headers [Re: Lew] #576482
01/08/10 10:14 AM
01/08/10 10:14 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I got tired of trying to fit hard lines around hearers and adding trans coolers, this time around I went to braided lines, it was so much easier.
Re: trans cooler lines with headers [Re: GTXKen] #576483
01/08/10 10:17 AM
01/08/10 10:17 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
i can see where that would work good and look good too.
Re: trans cooler lines with headers [Re: mcmopars] #576484
01/08/10 10:42 AM
01/08/10 10:42 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I searched thru all my old posts, and my pics of my lines have been purged. I have a Challenger with a small block, and TTI headers. What I did was install 2 bulkhead connectors in the radiator support,and plumb hard lines from there....down the frame rail behind the steering box. When I got to the area near the trans crossmember, I had 2 steel braided hoses made to go from the hard lines over to the transmission so there would be some flex to it. From the radiator support forward, I used a stack plate cooler and installed compression fittings in it and plumbed it hard line back to the bulkhead fittings. I'll never have factory lines on a hot rod again after doing it this way! Numbers matching,stock looking cars with no headers,yes.....hot rods,NO!
Re: trans cooler lines with headers [Re: GTXKen] #576485
01/08/10 12:10 PM
01/08/10 12:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not to mention that running aluminum lines up against, or close to, header pipes is undoubtedly heating your tranny fluid up. I ran braided line out to the frame rail and up, and have Much more peace of mind now.
Re: trans cooler lines with headers [Re: StealthWedge67] #576486
01/08/10 01:01 PM
01/08/10 01:01 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I bent my own hard lines. I got a cutter, dual flare tool, bender, and quite a bit of line from Summit all in a package deal. I've used the tools many times since then.
I ran my lines over and along the frame like someone mentioned earlier. It was a little difficult to do all in one bend but I got 1 correct but had to use a union in the other. It is a much cleaner look and the lines are nice and out of the way.
Re: trans cooler lines with headers [Re: GTXKen] #576487
01/09/10 06:32 AM
01/09/10 06:32 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i think the braided will be the way to go for me.thanks
Re: trans cooler lines with headers [Re: mcmopars] #576488
01/09/10 12:01 PM
01/09/10 12:01 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I assume they make braided line that is rated for trans fluid? I know if you use fuel rated rubber line on auto trans it will fail within months. It attacks and softens the rubber until it ruptures from the pressure. Lee.
Re: trans cooler lines with headers [Re: Lee446] #576489
01/09/10 12:21 PM
01/09/10 12:21 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
When I had a 904 I used braided hydrauic hose, I had a hose shop make them, just had to give the length and what fittings I wanted. It's rated for 3000psi which is way overkill for trans cooler lines but it was the cheapest thing they had that would hold up with ATF.
