Re: trans cooler lines with headers
[Re: Lew]
#576480
01/08/10 08:29 AM
01/08/10 08:29 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Are you guys using the hard lines specifically for the headers or are you using stock bent lines? I am just curious because when I added the TTi's to my 340 Challenger, I used my original steel lines on the radiator and at the tranny but I had to cut the middle 16" or so out of each one and use rubber "tranny cooler" lines to reroute without touching the headers or the steering link. I would love to go back to using all steel but the rubber is working just fine.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#576481
01/08/10 08:53 AM
01/08/10 08:53 AM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
Mine are hard all the way, they were not specified for headers when purchased if i recall correctly, like i said, some very minor clearance tweaks, fit great!
[Re: GTXKen]
#576483
01/08/10 10:17 AM
01/08/10 10:17 AM
Lew
Coolville, Ohio
I got tired of trying to fit hard lines around hearers and adding trans coolers, this time around I went to braided lines, it was so much easier.
i can see where that would work good and look good too.
[Re: mcmopars]
#576484
01/08/10 10:42 AM
01/08/10 10:42 AM
Posts: 8,485 Candler,NC / Myrtle Beach, SC
JDMopar
I searched thru all my old posts, and my pics of my lines have been purged. I have a Challenger with a small block, and TTI headers. What I did was install 2 bulkhead connectors in the radiator support,and plumb hard lines from there....down the frame rail behind the steering box. When I got to the area near the trans crossmember, I had 2 steel braided hoses made to go from the hard lines over to the transmission so there would be some flex to it. From the radiator support forward, I used a stack plate cooler and installed compression fittings in it and plumbed it hard line back to the bulkhead fittings. I'll never have factory lines on a hot rod again after doing it this way! Numbers matching,stock looking cars with no headers,yes.....hot rods,NO!
[Re: Lee446]
#576489
01/09/10 12:21 PM
01/09/10 12:21 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
I assume they make braided line that is rated for trans fluid? I know if you use fuel rated rubber line on auto trans it will fail within months. It attacks and softens the rubber until it ruptures from the pressure. Lee.
When I had a 904 I used braided hydrauic hose, I had a hose shop make them, just had to give the length and what fittings I wanted. It's rated for 3000psi which is way overkill for trans cooler lines but it was the cheapest thing they had that would hold up with ATF.
