Page 1 of 3 1 2 3
Old School TUNNEL RAM on 440 .can you drive on street ? #57630
05/02/08 08:44 AM
05/02/08 08:44 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I'm about to dig back into the DeSoto and rebuild the motor / trans and get it running since no one wants to buy it
And I'm considering putting a old tunnel ram intake on it just cause it will look kinda wild
The hood clearance should be fine ..How touchy are they anyone ever mess with one ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57631
05/02/08 09:39 AM
05/02/08 09:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
a blower would be more street friendly and give you more bang for the buck. plus it'd fit under the hood too.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: Mr.Yuck] #57632
05/02/08 10:20 AM
05/02/08 10:20 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I have about 7000 miles on my current setup - 16 mpg and VERY street friendly... 3.23 gears help
2 holley 390's w/ vac secondaries
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: DJVCuda] #57633
05/02/08 10:53 AM
05/02/08 10:53 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I ran one on my '70 SF when I was in high school. Two 4160's from j/yard c-bodies and away we went. I learned mucho about tuning holley's during that project. I do remember having to do something with the vac. secondaries to get them to work correctly together from carb to carb. With a stick it was very streetable.
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: Jeremiah] #57634
05/02/08 11:03 AM
05/02/08 11:03 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
http://holley.com/20-73.asp
thats all ya need...
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57635
05/02/08 01:58 PM
05/02/08 01:58 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
just got my 340 running with a way overcarbed eddy tunnelram with two 750 proform dubble pumpers on it and it runs alot better than i thought it would and i havent even started playing with it
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: 1Fast340] #57636
05/02/08 02:07 PM
05/02/08 02:07 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I agree with the vacuum secondaries, then the engine "takes what it needs" when you floor it. Mine is very responsive and streetable, although it took a LOT of tinkering with the dual Holley's. And don't listen to anyone that says it needs a progressive throttle linkage, it does NOT, both carbs should open the same.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: 4BBodies] #57637
05/02/08 03:12 PM
05/02/08 03:12 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I love the tunnel ram. Everyone that rides in the car is amazed at how nice it runs on the street.
Stan
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: 4BBodies] #57638
05/02/08 03:15 PM
05/02/08 03:15 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
that car would look pretty sweet if it had a big blower on top, no hood, and headers with side pipes, then paint the car with a roller in matte black, and red wheels.
but a giant tunnel ram would look cool too, the taller the better!
**Photobucket sucks**
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: 70Cuda383] #57639
05/02/08 04:36 PM
05/02/08 04:36 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The experiences big and small blk chevy guys have with tunnel rams on the street are not so with the 440 mopar. I have run an M1 with 2 500cfm eddies. Fantastic street setup. A guy on here ran one on his big block pickup truck and had no complaints. Keep the carbs small (youll have 2). I like the eddy 500s. If I were to run holleys theyd be the 600cfm vac secondaries.
Keep old mopars alive.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: 2boltmain] #57640
05/02/08 07:16 PM
05/02/08 07:16 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you are running a 4 speed or a big stall you will love it, lots of power up top. No real issues after you get the carbs jetted..
With a stock stall it will be pretty unresponsive in normal driving.
Re: Old School TUNNEL RAM on 440 .can you drive on stre [Re: sthemi] #57641
05/02/08 07:30 PM
05/02/08 07:30 PM
Nice looking DeSoto!
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57642
05/02/08 08:43 PM
05/02/08 08:43 PM
many moons ago...
400/ t-ram/ couple avs carbs/ stock cam/ convertor/ and 3.55 gears. ran like a champ on the street.
Re: Old School TUNNEL RAM on 440 .can you drive on street ? #57643
05/02/08 09:05 PM
05/02/08 09:05 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Once you get the carbs sorted out you'll wonder why everyone doesn't run one. I'll never go back to a regular manifold again. Last summer with the 750 eddys I was making 10mpg driving the 528 'nice'. 'Nice' is very difficult most of the time as your foot has a mind of it's own and likes to rest itself on the firewall. Dave
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57644
05/02/08 09:29 PM
05/02/08 09:29 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A lot of guys I knew ran Tunnel rams on the street, they work surprisingly well. One fellow in particular ran the Offy T-ram on a 440 with dual 750 mechanicals. That was a very streetable setup and ran a bunch harder than it did with a single 4 barrel.
Sheldon
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: RUNCHARGER] #57645
05/03/08 12:02 AM
05/03/08 12:02 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I bought one and two old dud carbs at a swap meet
wondering if i can use them without issues
Sounds like some have had a little luck
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: bigdad] #57646
05/03/08 12:43 AM
05/03/08 12:43 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
How about some of the Chrysler Long Ram intake manifolds on there. I know that Desoto has to be able to fit them on there.
Or better yet that Ramchargers setup they ran in the early days with the mailbox on top of it.....
I think the long rams would look very classy and give you great top end run on the highway
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: PHJ426] #57647
05/03/08 10:29 AM
05/03/08 10:29 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
There is room for the long rams but they are HIGH priced ..couple g's I think ?
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: quickd100] #57648
05/03/08 03:39 PM
05/03/08 03:39 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Oh, but I couldn't agree more.
My wife's daily driver for years was a tunnel rammed 440 Cordoba LS. Work, groceries, you name it.
I worked in construction and for years had a 440 tunnel rammed work truck, everybody thought I was fibbin until I popped the hood, or floored the gas pedal....
My work truck had a 268 Comp Cam and a STOCK stall converter, it had more bottom end balls than could be believed, it would ROAST the back tires while towing a 1937 Plymouth on a car trailer, I know from experience.
I've had a ton of tunnel rammed 440 vehicles, never had a problem with them and I would truly be hesitant to run a single four barrel on a 400 again.
My Coupe was a 440 tunnel ram when I had it on the road, I drove it all over all the time, it was my only insured vehicle.
Lots of hood clearance too.
CrAzYMoPaRGuY
Re: Old School TUNNEL RAM on 440 .can you drive on street ? [Re: CrAzYMoPaRGuY] #57649
05/03/08 04:22 PM
05/03/08 04:22 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Very Kewl!!!
What tunnel ram were you using?
I like the looks of of it!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Page 1 of 3 1 2 3
