1949 Dodge, sectioning and next is a chop #575641
01/07/10 10:56 AM
01/07/10 10:56 AM
SE Wisconsin
49wayfarer Offline OP
SE Wisconsin
I've been posting this on the HAMB, since I've been on there seeing how others have done it. I sectioned my car 2", and will be chopping the top next. The doors I peeled back the skin, sectioned the center, replaced the skin, and cut the remainder off the bottom. Fender looks good, will have some hammer and dolly work, only took 2" out because I still wanted some steel between the top of the wheel arch and top of the fender. Lots of spot welds!
http://www.jalopyjournal.com/forum/showthread.php?t=430749
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575642
01/07/10 10:59 AM
01/07/10 10:59 AM
SE Wisconsin
SE Wisconsin
Heres the doors, before and after.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575643
01/07/10 09:38 PM
01/07/10 09:38 PM
moparx Offline
moparx  Offline
is this a "slope back" ? what are your plans for it? custom,gasser, or ?????? that was a good way to section your door. what do you plan to do on the body ? lookin good !
Re: 1949 Dodge, sectioning and next is a chop [Re: moparx] #575644
01/08/10 12:00 AM
01/08/10 12:00 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wow very kool,a lot of work,cant wait to see more,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: moparx] #575645
01/08/10 12:01 AM
01/08/10 12:01 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wow very kool.a lot of work cant wait to see more on this build
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575646
01/11/10 07:35 PM
01/11/10 07:35 PM
SE Wisconsin
SE Wisconsin
Started bracing the car and I chopped it 3". Hard part is going to be forming a piece to fit behind the rear window, as I had to move it froward to look right, couldn't just lay it down.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575647
01/12/10 02:47 AM
01/12/10 02:47 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
hard to tell from the pic,, did you move the entire roof forward or just the rear glass section ?
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575648
01/12/10 05:13 PM
01/12/10 05:13 PM
SE Wisconsin
SE Wisconsin
I chopped the roof 3" and then had to move the rear window forward to get the right roofline.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575649
01/17/10 03:06 AM
01/17/10 03:06 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
kool cant wait to see more on this build
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575650
01/30/10 01:55 AM
01/30/10 01:55 AM
SE Wisconsin
SE Wisconsin
Started filling in around the window.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575651
01/31/10 01:31 AM
01/31/10 01:31 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
sorta looks like a 48-50 merc window laying down like that ,,your work looks great,,
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575652
02/28/10 03:24 PM
02/28/10 03:24 PM
Iowa,US
4bbl Offline
4bbl  Offline
Iowa,US
Nice job!
4bbl If you can't hear it coming what's the point.......
Re: 1949 Dodge, sectioning and next is a chop [Re: 4bbl] #575653
03/07/10 10:58 PM
03/07/10 10:58 PM
SE Wisconsin
SE Wisconsin
Got some more work on it, all welds are done and ground around the window, lot of hammer and dolly work. I couldn't grind the welds down enough so you can still see them. Don't know how some guys can weld and finish their metal so much you can't see the welds. Need to finish the firewall and rockers next.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575654
03/07/10 10:59 PM
03/07/10 10:59 PM
SE Wisconsin
SE Wisconsin
another view
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575655
03/08/10 01:43 AM
03/08/10 01:43 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looking great,, how about a pic from the front over all
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575656
03/08/10 08:57 PM
03/08/10 08:57 PM
SE Wisconsin
SE Wisconsin
Hope to make some room in my garage and roll it out soon. Then I'll put the hood back on and see how it looks.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575657
03/09/10 02:33 AM
03/09/10 02:33 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
cant wait to see it
2015 cherokee
2013 R/T classic
Re: 1949 Dodge, sectioning and next is a chop [Re: fstfish66] #575658
03/18/10 11:44 PM
03/18/10 11:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looking great Andy, I am very impressed! Give me a call sometime. I'd love to catch up.
Re: 1949 Dodge, sectioning and next is a chop [Re: Jeremiah] #575659
03/23/10 08:57 PM
03/23/10 08:57 PM
SE Wisconsin
SE Wisconsin
Snows gone, rolled it out to get a better view. Not sure if I should have chopped more. Its 5" shorter overall between the section and chop.
Re: 1949 Dodge, sectioning and next is a chop [Re: 49wayfarer] #575660
03/24/10 05:04 AM
03/24/10 05:04 AM
places
79powerwagon Offline
places
No, it's spot-on!
