My 4 speed has the drips #575474
01/06/10 10:43 PM
01/06/10 10:43 PM
Virginia
MACDiesel Offline OP
Virginia
I have a small leak from the front of my A833. Anybody ever replaced the front seal? I've never worked on a A833 before. It would be nice to know what I'm getting into before I pull it and make a big problem out of a little problem.
-1967 Belvedere II 440/4speed
Re: My 4 speed has the drips [Re: MACDiesel] #575475
01/06/10 11:09 PM
01/06/10 11:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That would be one of the easiest seals to replace.Just remove the 4 bolts holding the front retainer on and install a new seal.Make sure to order a new gasket as well.
Call Jamie Passon 570-401-8949
Gus
64 Plymouth Savoy
Dana 60
Re: My 4 speed has the drips [Re: MACDiesel] #575476
01/06/10 11:37 PM
01/06/10 11:37 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Do you have synthetic oil in it? I replaced my old gear oil with Amsoil synthetic and it leaked all over and would not shift smoothly. Went back to regular gear oil.
Re: My 4 speed has the drips [Re: fastmark] #575477
01/07/10 12:17 AM
01/07/10 12:17 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
You also need to check the bearing retainer for cracks at the bolt holes. Very common when bolts get over tightened. Also be sure that you have the correct bolts and use a sealant under the head.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: My 4 speed has the drips [Re: fastmark] #575478
01/07/10 12:28 AM
01/07/10 12:28 AM
Idaho
Runner Offline
Runner  Offline
Idaho
i went from a 75-90 gear oil to redline mtl and it now shifts WAY better. from now on that or penzoil synchomesh is all ill use. the tranny does not leak with synthetic either. all my gaskets and seals are only 2 hears onld though.
Re: My 4 speed has the drips [Re: Runner] #575479
01/07/10 12:07 PM
01/07/10 12:07 PM
Virginia
Virginia
I was going to use royal purple 140wt. I got the '67 plymouth manual and that's the weight it suggest.
Re: My 4 speed has the drips [Re: Runner] #575480
01/07/10 12:34 PM
01/07/10 12:34 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Redline is all i use. No leaks , great shifts. In Extreme cold a cold 4speed will be a sticky 4speed
