Dual exhaust heat shield/brackets question, e-body. #574435
01/05/10 10:55 PM
01/05/10 10:55 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, I will be converting my barracuda from a single exhaust to a dual exhaust. Will I need another factory style heat shield for the other side? Also, should I purchase the factory brackets for the pipe that goes over the rear and the one that bolts to the rear frame. I'm not sure how this is done, and I don't have any pictures showing the mounting details. Thanks.
Re: Dual exhaust heat shield/brackets question, e-body. [Re: cudabitten] #574436
01/07/10 08:07 PM
01/07/10 08:07 PM
eastern, pa.
eastern, pa.
Going to ask this again, anyone have any ideas,thoughts?
Re: Dual exhaust heat shield/brackets question, e-body. [Re: cudabitten] #574437
01/07/10 08:20 PM
01/07/10 08:20 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I think the shield was for the resonator they ran on those cars. Probably won't need to get another shield if you don't plan on putting resonator on that side.
Re: Dual exhaust heat shield/brackets question, e-body. [Re: migsBIG] #574438
01/07/10 08:42 PM
01/07/10 08:42 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
depends if u are going stock or buying a kit like a tti....it comes with their own brackets....some kits come this way..if going the stock route u will need it
Re: Dual exhaust heat shield/brackets question, e-body. [Re: AARCONV] #574439
01/08/10 11:02 AM
01/08/10 11:02 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
THe shields are at the back of the car above the mufflers. The resonators didn't use a sheild. Yes you will need to buy a drivers side sheild if you are running the stock style round mufflers at the back.
The 73 style passengers side tail pipe hanger is sold by Accuarate Exhaust. They are a sponcer of this site. There is a bracket that is either welded or rivited to the shock X-member on the passengers side. That is what the hanger bolts to.
Re: Dual exhaust heat shield/brackets question, e-body. [Re: burdar] #574440
01/08/10 11:18 AM
01/08/10 11:18 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
You dont need any of the sheilds if using an aftermarket type exhaust (TTI/Summit /Pypes )or a custom exhaust that does not locate any mufflers under the trunk. Most exhaust systems just use talipipes in that area. Unless you doin a OE type resto just toss the sheilds. I really like the TTI system for the E-Body with the X-pipe.
