Page 3 of 3 1 2 3
Re: head swap to B1 BS HP gain? [Re: HardcoreB] #574141
01/10/10 05:52 PM
01/10/10 05:52 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
Re: head swap to B1 BS HP gain? [Re: HardcoreB] #574142
01/10/10 05:55 PM
01/10/10 05:55 PM
gregsdart Offline
gregsdart  Offline
I am far from an expert on blowers, but have some basic understanding of them, having messed with one a bit.
If you put a head on that flows ten percent better, and show a large drop in boost, bring the boost back up to 12 lb and the differance should be roughly the same increase in total pressure brought back into the picture.
12 psi boost, plus atmospheric pressure would be 26.7 absolute psi. If you loose 2.67 psi on the head change, then increase the boost back to 12 psi, it might show a 100 hp increase. There are a lot of variables
i don't know about on this type of blower, so take it as a WAG.
Re: head swap to B1 BS HP gain? [Re: gregsdart] #574143
01/10/10 06:01 PM
01/10/10 06:01 PM
ELYRIA,OH
ELYRIA,OH
i agree.i am upgrading the heads to gain HP, reduce heat/restriction plus my 346 iron heads are at there limit for putting $$ into.
Re: head swap to B1 BS HP gain? [Re: blownzoom440] #574144
01/10/10 07:34 PM
01/10/10 07:34 PM
ELYRIA,OH
ELYRIA,OH
its not just that increase in HP for me as i will be turning up the boost to about 1300HP now and then. about 16 psi i would guess.
Re: head swap to B1 BS HP gain? [Re: blownzoom440] #574145
01/10/10 07:39 PM
01/10/10 07:39 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: head swap to B1 BS HP gain? [Re: Von] #574146
01/13/10 11:03 AM
01/13/10 11:03 AM
Alvin, Tx, US
bpattp444 Offline
bpattp444  Offline
Alvin, Tx, US
I run a set of Koffels ported B1/BS heads with the B1 Intake. The ports are bigger than the MW ports. The B1 intake is cut big time.
Tube Chassie Truck
2785 LB PG Trans
1.21 60'
5.57 1/8
8.76 1/4
Re: head swap to B1 BS HP gain? [Re: blownzoom440] #574147
01/14/10 12:44 PM
01/14/10 12:44 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
i have harland sharp that will work but i need to change the intake rocker to the correct offset and HS sells those.sorry you had problems with the springs,valves...
Back in the 90s board member MRMOPAR pretty much ran the combo you are looking at. IIRC it was a .040 stock stroke 440 with Pro Gram Main Caps, a Callies Crank, Ferea Rods, Crower 280R roller with a GMC 6-71 on a Dyers intake with a pair of 850s from the supercharger store (?) and the B1BS heads. I don't believe that the heads were ported at all - just OOTB, and I am not convinced that they did all that much over the iron heads they replaced. In other words, I don't think I would bother without porting them.
I believe he still has a set of the special offset B1BS Harland Sharp rockers that he would be willing to unload. Try sending him a PM.
Re: head swap to B1 BS HP gain? [Re: Bill_T] #574148
01/14/10 03:03 PM
01/14/10 03:03 PM
ELYRIA,OH
ELYRIA,OH
interesting! thanks.
mine will be made to flow as stated in the 330 range so it will be better than the 280 cfm i had from the iron heads. i am sure the new rockers have a better baring now from then.i will check.
Page 3 of 3 1 2 3
