470 lowdeck stroker/ anyone try it? #572056
01/04/10 06:04 AM
01/04/10 06:04 AM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
Ive gotten some great responses on my stroker question i posted a few days ago. I was wondering if anyone on the board uses or know someone who has used a 470 kit in there 400 low deck. Indy is having a sale on these completely assembled for 2100 bucks! I just wanna know if there any good. You guys are the best. Thanks for the help!
"I aint here on buisness baby,Iam only here for fun"
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572057
01/04/10 08:26 AM
01/04/10 08:26 AM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
Contact Tonys451, he had one in his 4000 lb 65 wagon and did a best 10.98.
3 Darts and a Ram
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572058
01/04/10 08:59 AM
01/04/10 08:59 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Members and sponsers of this board got together for a PHR Enginemasters challange assembled one back in 2003 that made over 700hp ...
Re: 470 lowdeck stroker/ anyone try it? [Re: JohnRR] #572059
01/04/10 09:08 AM
01/04/10 09:08 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Buddy tells me it's probably the best all around mopar race motor. Another friend runs 9.80's in a demon with one.
Coming soon!!!!
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572060
01/04/10 09:49 AM
01/04/10 09:49 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Steve Dulcich did well with his 2003 Engine-Masters 470 entry.
http://www.popularhotrodding.com/enginemasters/challenge/2003/0405phr_emc3/index.html
3'd place and highest overall HP.
Peak HP: 752@ 6,500 rpm
Peak TQ: 641.9@ 5,500 rpm
Avg. HP: 547
Avg. TQ: 598.8
Re: 470 lowdeck stroker/ anyone try it? [Re: topbrent] #572061
01/04/10 10:14 AM
01/04/10 10:14 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
The one in my Duster has been together for many years. Requires little or no maint. to keep it going. Have a .613" flat tappet cam and about 12 to 1 compression. Car weighs about 3300 w/me in it and runs 10.50's anywhere. Will be into the 30's and 20's if I tweak it. Great combo thus far. See ya, Ken Michalik
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572062
01/04/10 10:23 AM
01/04/10 10:23 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
If you consider all the factors in building a performance engine, And plan on using a std port cylinder head. The 470 is THE best combo out there for stock port opening heads. Light bob weight, big bore, good amount of stroke/cubes, ideal "all purpose" rod ratio make this a very good kit. These combos typically work better than they "should" because it is a well balanced combination FOR stock port sized cylinder heads.
Mike @MM
Re: 470 lowdeck stroker/ anyone try it? [Re: MuscleMike] #572063
01/04/10 10:39 AM
01/04/10 10:39 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i used to put together a 470 for some friends. it was in a '67 gtx, about 3200lbs, with stage 6 heads. ran a few 9.90's at 134mph. definetly one of my favorite combo's.
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572064
01/04/10 11:19 AM
01/04/10 11:19 AM
fresno ca
mikeysmopars Offline
fresno ca
I paid right at $4000 for mine with bushed lifter galleys and good bottom parts. Went a best of 10.48 at 129 with Indy EZ heads in a 3300 lb car.
I like Mine
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 470 lowdeck stroker/ anyone try it? [Re: mikeysmopars] #572065
01/04/10 11:32 AM
01/04/10 11:32 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I've got one one the street. Even at high altitude it's all I wanted and more. 3800 lbs at altitude and pulles hard at all RPM's. Couldn't be happier.
Re: 470 lowdeck stroker/ anyone try it? [Re: BELVEDERE67] #572066
01/04/10 11:55 AM
01/04/10 11:55 AM
1swingin Offline OP
1swingin  Offline OP
Great feedback! How much block clearance was involved? Also, I just got off the phone with indy. 1495 for rotating assembly. Not a bad deal at all but they sure are lacking in the customer service department! I will spend the extra 400 and go with muscle motors kit. Just cause my car dont say superstock or my name isnt warren johnson they dont have time for me!
Re: 470 lowdeck stroker/ anyone try it? [Re: MuscleMike] #572067
01/04/10 11:59 AM
01/04/10 11:59 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I am in 100% agreement with Mike. Although many people get all wrapped up in 'bigger is better", I still think the 470 motor is hands down one of the best for the buck, and many off the shelf parts are available now as well for it. 451" ranks right up there, and of course the 493 and 511's are probably next on my list of simple but overachievable combos.
Todd
RIP Monte Smith
Post deleted by moparts [Re: 1swingin] #572068
01/04/10 07:04 PM
01/04/10 07:04 PM
Re: 470 lowdeck stroker/ anyone try it? #572069
01/04/10 07:15 PM
01/04/10 07:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree, the 451 and 470 combos are just awesome for the price. When I was running high 9's with an Eddy headed 451 and 590 purpleshaft cam I use to laugh at all the 500" Indy headed roller motors running low 10's. Now I have one of those 500" turds but it's finally starting to come around now with a 9.82. I just think the 500" 440-1 motors need alot of compression to really make them work and I don't have the cam or compression to really make it fly.
I think a 470" motor with a real good set of Victors or EZ's or whatever and a 590 purpleshaft can easily go high 9's and not break the bank, also very streetable and reliable.
Re: 470 lowdeck stroker/ anyone try it? #572070
01/04/10 07:16 PM
01/04/10 07:16 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Here is a little 470.Lot bang for the buck!!!!
http://www.youtube.com/watch?v=eOEIpLxFSIs
Re: 470 lowdeck stroker/ anyone try it? [Re: ProSport] #572071
01/04/10 07:33 PM
01/04/10 07:33 PM
AndyF Online content
AndyF  Online Content
Yep, the combination is really important. I've seen a number of those 440-1 headed slugs at the track also. Not that they can't be made to work but the 451 or 470 with standard port heads just seems to be a little easier for the average guy to get a handle on.
As for the original question; yes, lots of people have built 470 inch motors over the years. I was building them more than 15 years ago and I wasn't the first guy to do it. Back then we had to offset grind OEM cranks because nobody was making new forgings. These days you can just whip out the VISA card and order up a rotating assembly.
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572072
01/04/10 07:33 PM
01/04/10 07:33 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
I'm happy with mine. Steath heads, flat solid cam in a 97 Dakota runs low 10s.
Re: 470 lowdeck stroker/ anyone try it? [Re: challenger73400] #572073
01/04/10 08:35 PM
01/04/10 08:35 PM
CDoering Offline
CDoering  Offline
Is anyone making off the shelf pistons for the 470 using a 6.385 rod? I have a nice set of Crower rods but after looking at a bunch of different piston manufactures I don't see anything listed. It looks like most of the kits now use a longer rod.
After looking at an Indy advertisement they show their 470 kit using 6.385 rods, but I have not called them to see if they stock that piston.
Re: 470 lowdeck stroker/ anyone try it? [Re: CDoering] #572074
01/04/10 08:42 PM
01/04/10 08:42 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I prefer a 470 Low deck to a 493RB for the same money. The 470 is a great bucks down combination in both blocks that's real easy on parts and runs forever when carefully assembled...3.90 stroke is the same as a 455 Buick BTW
WIZE
In Car:
Re: 470 lowdeck stroker/ anyone try it? [Re: CDoering] #572075
01/04/10 08:51 PM
01/04/10 08:51 PM
8secDart Offline
8secDart  Offline
Wiseco I think has them.That is the same combo in the Duster.I got them from Indy years ago.
