Hydraulic Flat Tappet Lifters? #571662
01/03/10 07:31 PM
01/03/10 07:31 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I need to buy a set of lifters for my engine build. I ordered a Racer Brown cam but didn't buy lifters with it. I have heard there are only a couple of US companies making lifters. Does anyone know which lifter I can buy to make sure I get one of the US made lifters? Also not looking for an Anti Pump Up. Low RPM street car.
Thanks,
Steve
Re: Hydraulic Flat Tappet Lifters? [Re: srunge55] #571663
01/03/10 09:50 PM
01/03/10 09:50 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Thanks,
Steve
Big block? Arruzza has a nice set with a C clip instead of the wire bale.
Re: Hydraulic Flat Tappet Lifters? [Re: torkrules] #571664
01/04/10 12:57 AM
01/04/10 12:57 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
yes its a big block. Do you know who makes Aruza's?
Re: Hydraulic Flat Tappet Lifters? [Re: srunge55] #571665
01/04/10 04:05 PM
01/04/10 04:05 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Not sure who makes them. If you look on his web site it will list these as Johnson bodies which is one of the larger lifter manufacturers in the US. He is one of the site sponsors. The outer bodies looks very similar to comp cams outer body.
The guts look the same as those supplied by Mopar (not sure where they get their lifters). He lists them as Hemi lifters but they will work in a big block.
