BB Race engine weight..... #570457
01/02/10 10:52 PM
01/02/10 10:52 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Just curious if you guys have ever weighed your BB race motors..Just curious what you have seen for weights. I will refrain from posting mine til after I see some of the others out there. Mine is a KB aluminum low deck block with B1 heads. I did weight my old World Hemi block and it was 308 especially after weighing the current engine.
Re: BB Race engine weight..... [Re: Al_Alguire] #570458
01/02/10 11:08 PM
01/02/10 11:08 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
My college buddy was a SB guy and referred to the RB motors as "Road Blocks" because they are so fricken heavy (and that was before aftermarket blocks). Don't have a scale capable of weighing one. Will be interested in the reponses.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: BB Race engine weight..... [Re: Al_Alguire] #570459
01/03/10 12:02 AM
01/03/10 12:02 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what was on it when you weighed it Al (intake, carb, oiling system, cam drive, steel/aluminum rods, etc.)? i'm curious as i'm building a similar setup but a raised deck. the b1 heads are no lightweight for aluminum heads there's a lot of material there
Re: BB Race engine weight..... [Re: jamesc] #570460
01/03/10 12:10 AM
01/03/10 12:10 AM
Las Vegas
Las Vegas
Complete....As it goes in the car. I only know because we have it out know while doing some painting. Just put it on the scales...
Re: BB Race engine weight..... [Re: Al_Alguire] #570461
01/03/10 01:21 AM
01/03/10 01:21 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Everything less carb, world Aluminum block, B1 heads, oiling system, air pump, w/pump, dist, ect. in the plastic crate 45# for the crate, no oil, water, 685#'s
Re: BB Race engine weight..... [Re: camastomcat] #570462
01/03/10 10:23 AM
01/03/10 10:23 AM
gregsdart Offline
gregsdart  Offline
I never have weighed the whole package, but the crank is 70 lbs, the machined 4.500 mega block came in at 250 lbs, and the injection is light. Terminator is about 1/4 the weight of a dominator. Rods, 910 grams.
Re: BB Race engine weight..... [Re: gregsdart] #570463
01/03/10 10:49 AM
01/03/10 10:49 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
not when you add in all the other parts needed to perform the same task. Ie, dist. block, lines and nozzles, leanout valves, etc.
Don't really know what my alum. head bbc's weight but on oak pallet with plywood sides and top, engine cradle carb to pan with trigger, vac pump, etc. topped 800# shipping weight.
Re: BB Race engine weight..... [Re: jamesc] #570464
01/03/10 08:40 PM
01/03/10 08:40 PM
sg66mopar Offline
sg66mopar  Offline
Guess I should've weighed mine while it still had the Indy 440-1' on it. Sounds like the B1s are gonna slow the car down from all the extra weight!
Oh that's right, my UPS scale might not handle this boat anchor anyway.
Re: BB Race engine weight..... [Re: sg66mopar] #570465
01/06/10 12:56 AM
01/06/10 12:56 AM
Las Vegas
Las Vegas
Sorry guys I forgot about this one. I came in just a tick over 500lbs, everything but water.
