Why did the shoe in my Steering Coupler break? #569948
01/02/10 02:22 PM
01/02/10 02:22 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
While removing my steering box for R&R, I disconnected the steering coupling. No problem in the process. When dismantling the coupler I discovered that one of the shoes inside the coupler was broken. All the other parts, including the coupler itself, seem fine (photo attached). I do have a coupling rebuild kit, so all the guts of the coupler will be replaced.
A little history:
The car, '68 RR was originally a manual steering car. One of the previous owners converted it to power steering so I know the coupling was off at some point in the cars life.
What may have caused this?
I want to make sure this doesn't happen again.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569949
01/02/10 02:47 PM
01/02/10 02:47 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
never saw that before. maybe it was dropped and had a small fracture on it before it was installed and it let go
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Why did the shoe in my Steering Coupler break? [Re: aarcuda] #569950
01/02/10 04:15 PM
01/02/10 04:15 PM
If the pieces in there were positioned correctly which I'm sure they were as you'd have a ton of play if you had them sideways I'd say just a (very rare) defect in the metallurgy. I'd grab a new kit (only $10-12 or so) & I think you'll be fine but I would give everything inside the coupler a good visual inspection.
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569951
01/02/10 04:25 PM
01/02/10 04:25 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
A little history:
Frank
Is it possibl it was put in backwards?
Re: Why did the shoe in my Steering Coupler break? [Re: 340dart4spd ] #569952
01/02/10 05:52 PM
01/02/10 05:52 PM
Is it possible it was put in backwards?
It could have been. When I pulled the coupler off of the steering shaft the broken pieces fell to the floor. The other shoe stayed on the shaft due to the grease around it. Never thought about checking the original orientation since when the one side fell I didn't know it was broken.
I doubt it was in wrong but it's possible.
When looking at the broken shoe it's as though it was a cold break in the metal. Don't know if it was a stress break or not.
Frank
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569953
01/02/10 10:05 PM
01/02/10 10:05 PM
A for me
Anybody from the night shift have any ideas?
Frank
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569954
01/02/10 10:33 PM
01/02/10 10:33 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Why worry over something no one can give you the for sure answer on. No doubt someone boned up at some time. Put it togeather right and you will have no worries.
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569955
01/02/10 10:34 PM
01/02/10 10:34 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Hey Frank,
Never tried to install them backwards, don't think it's possible. Also by the wear marks it appears it was installed the correct way. Can't say I have ever pulled one out cracked like that, even the ones that are installed sideways.
Re: Why did the shoe in my Steering Coupler break? [Re: rrunner] #569956
01/02/10 10:50 PM
01/02/10 10:50 PM
I just want to make sure I don't make the same mistake (if there was one) like the last guy.
I'm not worried about putting it back together correctly, I know I can do that. I just wanted to know if someone may of had another reason this could have happened that I was not aware of.
Thanks for the input guys.
Frank
Re: Why did the shoe in my Steering Coupler break? [Re: rrunner] #569957
01/02/10 10:55 PM
01/02/10 10:55 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Hey Frank,
Trust me it will go in backwards.. don't ask me how I know.... that was 25 years ago...LOL
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569958
01/02/10 10:56 PM
01/02/10 10:56 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
The only thing I would think to check is to make sure your steering shaft isn't bent and possibly the box mounting. I know you are replacing the box and got a new shoe kit so as long as the shaft and mounting surface are good you should be good to go.
Re: Why did the shoe in my Steering Coupler break? [Re: rrunner] #569959
01/02/10 11:03 PM
01/02/10 11:03 PM
10-4
Frank
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569960
01/03/10 12:58 AM
01/03/10 12:58 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I do have faith in the installed backwards theory but since you are digging. Is the steering shaft from the conversion too long and bottoming the coupler out?
Re: Why did the shoe in my Steering Coupler break? [Re: Magnum] #569961
01/03/10 02:29 AM
01/03/10 02:29 AM
Good Point.
I don't know. The steering box is out and I am waiting for my new one.
From reading the FSM it appears that you adjust the depth of the shaft in the coupler after you assemble and monunt it to the box. Once you adjust the depth you secure the steering column, unless I'm reading something wrong. I just skimmed over the reassembly section since I'm not quite there yet, but it's something I'm gonna check out.
You may be onto something.
Thanks for the insight.
Frank
Re: Why did the shoe in my Steering Coupler break? [Re: Chi_Town_Runner] #569962
01/03/10 10:00 AM
01/03/10 10:00 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
No help here, as I've never seen a break like that, and I've owned 10 different daily driven 78-90 4x4 full-size dodges in 25 years w/out borgesin. Rust belt too.
