Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: 440 Source kit update part 1 [Re: Quicktree] #569618
01/05/10 10:20 PM
01/05/10 10:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I can see it coming now! My kit was good / my kit was bad...
Mopar Performance
Re: 440 Source kit update part 1 [Re: B G Racing] #569619
01/05/10 10:32 PM
01/05/10 10:32 PM
NC
440Jim Offline
440Jim  Offline
NC
Flange face and radius,rough and unequal.
What is interesting, is that BG's crank flange has a scallop cut which appears about where the drill bit to cut the journal lightening hole would be; mine doesn't have that scallop cut. And that cut might allow that hole to be drilled straight?
Re: 440 Source kit update part 1 [Re: 440Jim] #569620
01/05/10 10:36 PM
01/05/10 10:36 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I think this needs more scrutiny before coming to a conclusion.
I am looking at my 440Source 4.250" crank (RB) and both the 5-6 and 7-8 rod journals have the lightening hole at an angle.
Very interesting, it seems it was intentional. You can put me in the group who didin't ASSUME it was defective without a clue what was going on.
i had some reputable people look at my 3.75 stroke 440 source crank and it passed tech.
For what it's worth, I had my 440 Source 400/500 kit shipped to a very picky machinist. He scoffed at the fact that I paid extra for a balance and I had to hear about the other 'balanced' kits he'd worked on that were terrible. I told him to check everything out and rebalance if necessary. When I picked it up he didn't have one complaint and I paid a very small fee for them to check the balance. He did substitute the Clevite rod bearings for ACL versions though.
Re: 440 Source kit update part 1 [Re: moparniac] #569621
01/05/10 10:36 PM
01/05/10 10:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ive seen factory cranks that werent drilled all the way through or perfectly centered. What was left though was paper thin pretty much.
I just ripped it out and finished it with a dremmel. As I didnt want that stuff ripping itself of and Finding its way to the oil system, as Bob eluded to.
Now on the steep angle/ dont recall Dont know if that would be a problem or not.
Of the Two 440 Source kits I had one was Bad and one wazs Good just kidding thats for 540
mike
Re: 440 Source kit update part 1 [Re: 493_DART] #569622
01/05/10 11:20 PM
01/05/10 11:20 PM
iowa
rook440 Offline
rook440  Offline
iowa
I'M from Creston ,and race there once in a while ,hopefully a bunch this year >>>>.
Re: 440 Source kit update part 1 [Re: 440Jim] #569623
01/06/10 08:18 AM
01/06/10 08:18 AM
snook Offline
snook  Offline
I'm with you on this one Jim. In fact, one can argue that an angle bore would actually be beneficial, it could minimize flexing, especially in crank center throws at speed. My two cents.
Re: 440 Source kit update part 1 [Re: 440Jim] #569624
01/06/10 09:39 AM
01/06/10 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Look at the placement of that hole, it's not even in the center of the rod throw looking at this picture .
Very informative thread BG ...
Re: 440 Source kit update part 1 [Re: 440Jim] #569625
01/06/10 10:34 AM
01/06/10 10:34 AM
Eighty Four, PA
B G Racing Offline OP
Eighty Four, PA
I'am in agreement that the journal hole may have been angle cut because of counter weight clearence issues,but fact that it was not finished(regardless) of where it exited there will be a true unbalance in the middle of the crank unless the material left was compensated in balance at the crank counter weights.The question is how much weight was left?If removed this would be a moot point. the crank balance would never show this unbalance area as it is balanced to the front and back axis.I will go out on a limb to say that this was not done,if it was its an expensive process and would be reflected in the crank cost.
Re: 440 Source kit update part 1 [Re: B G Racing] #569626
01/06/10 10:40 AM
01/06/10 10:40 AM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
Anybody got a 440source crank bought in the last year to compare pictures with???? It would be interesting to see if the new stuff is still being done the same way.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: 440 Source kit update part 1 [Re: JohnRR] #569627
01/06/10 10:48 AM
01/06/10 10:48 AM
NC
440Jim Offline
440Jim  Offline
NC
I don't know for sure, but remember there are oil holes going from the rod journal surface to the main bearings. So, placement of the lightening hole may not be able to be "centered". Depends on lightening hole dia and location of the oil holes.
Re: 440 Source kit update part 1 [Re: 440Jim] #569628
01/06/10 10:51 AM
01/06/10 10:51 AM
NC
440Jim Offline
440Jim  Offline
NC
I am looking at my 440Source 4.250" crank (RB) and ...
It appears the 5-6 journal is drilled larger (0.79" dia) and not as deep as the others which are all the way through and about 0.71" dia. The larger bit/tooling for the 5-6 requires it to be at a slightly larger angle than 7-8 and the amount of metal removed may be the same.
BG, what are the dia of the lightening holes on your low deck (B) crank for comparison?
I am wondering if the B and RB are drilled differently, or it could be a production change (different years, mine is 2007).
Re: 440 Source kit update part 1 [Re: 440Jim] #569629
01/06/10 10:52 AM
01/06/10 10:52 AM
Eighty Four, PA
Eighty Four, PA
Good point Jim,I'am going to look at the oil hole passages tonight.
Re: 440 Source kit update part 1 [Re: B G Racing] #569630
01/06/10 12:40 PM
01/06/10 12:40 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
For me it looks as the factory knows a lot about how to do a crank correctly, and many people here have learnt a lot about it on this thread.
Most other aftermarket cranks I have worked with are made the same way. Probably they are from the same factory?
Thanks!
Re: 440 Source kit update part 1 [Re: B G Racing] #569631
01/06/10 12:45 PM
01/06/10 12:45 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not that this "means" anything, but I just went out in the shop and looked at various cranks I have for some BBM and BBC engine projects I am working on. The cranks range from a Bryant Billet, a Lunati Pro-Series, an Eagle and 3 Callies. NOT ONE, has a lightening hole in a rod journal drilled at an angle, nor do the dozen or so factory cranks I have sitting around. IMHO, I would NOT run that crank in an engine with decent power. You have effectively weakened the throw into the cheek and that would be a likely place for a break. This is where cast cranks always break and while this is not a cast crank, the crank is most certainly weakened that area. As to whether this is corrected on later cranks....who knows, crap shoot at best. Again, based on what has been seen, YOU MUST CHECK these parts, old or new.
Monte
Re: 440 Source kit update part 1 [Re: Oyvind Mopar] #569632
01/06/10 12:46 PM
01/06/10 12:46 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, here is a pic to show where the oil passage is in relation to the rod journal lightening hole. I put a dowl in the oil hole to help judge where it goes. Not a big offset on this crank.
Re: 440 Source kit update part 1 [Re: DCI] #569633
01/06/10 01:12 PM
01/06/10 01:12 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I didn't take pics 'cause my camera is a POS but here's the sccop on my 440Source crank
1) 4.375 stroker
2) no scallop on the back flange - probably not necessary for drilling with the longer throws.
3) flange is nicely finished with consistent thickness
4) front and rear throws are drilled right through with 5/8" bit. Drilled straight.
5) middle two throws are partially drilled - about 1-1/2" deep, 5/8" bit, AT AN ANGLE. Had they drilled right through then these two holes would have come out in the thrust area as well.
Why are they at an angle? My guess is the bit isn't long enough to come in from either end without the chuck hitting the crank somewhere. That may have something to do with the torsional load on the bit over that length. Most factory cranks I've seen have much larger holes so the longer bit would tolerate the torsional loads. Or maybe the manufacturer is just too cheap to buy a longer bit.
Re: 440 Source kit update part 1 [Re: Monte_Smith] #569634
01/06/10 03:24 PM
01/06/10 03:24 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know if BG's crank is defective or a strange design, but FWIW.
I just looked at one of my old factory 440 steel cranks. The two middle rod journals did not have any lightening hole at all. And the front and rear journal holes were not drilled all the way through, not even close. I recall seeing some that had 3 journals drilled, 2, etc. Lots of different designs.
The angle is odd. IMO a very small angle is nothing, but a large angle into the wrong part of the journal is another story. I can't tell from where I sit...
I think I am ready to move past the crank and hear about the rest of the parts BG has.
Re: 440 Source kit update part 1 [Re: Stanton] #569635
01/06/10 03:28 PM
01/06/10 03:28 PM
NC
440Jim Offline
440Jim  Offline
NC
Interesting that the lightening holes in your 440Source crank are a different diameter than mine. Lots of different designs... (4.250 vs 4.375?) It will be interesting to hear what BG's 4.250 hole diameters are.
Re: 440 Source kit update part 1 [Re: 440Jim] #569636
01/06/10 03:51 PM
01/06/10 03:51 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I've just had a look through some pictures I took of my engine while I was building it and all four rod journals are drilled all the way through. It's a 440 Source 4.25" crank and I bought it in August 2007.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 440 Source kit update part 1 [Re: Mick70RR] #569637
01/06/10 04:44 PM
01/06/10 04:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
here's the whole deal in a nutshell
the cheap kits will run you close to 2k by the time everything is said and done.
you can get a better kit K1 for $2400
so thats around $400 more and you get a top of the line kit for a little over 3K.
it's a no brainer to me
