Speed Sensors on A518's #56925
04/21/08 05:49 PM
04/21/08 05:49 PM
IMGTX Offline OP
IMGTX  Offline OP
I am currently swapping an 5.9 magnum & A518 into my car. I am keeping the factory EFI, Computer etc. My current hitch is the speed Sensor.
The OEM one in 94 was a 3 wire unit with no provisions for a speedometer cable. I want to use the factory Speedo but need the signal for the Engine Controller.
I picked up a pass through speed sensor off of a Dodge van but it only has 2 wires instead of three.
Is this adaptable or do I need to look elsewhere?
Re: Speed Sensors on A518's [Re: IMGTX] #56926
04/21/08 06:06 PM
04/21/08 06:06 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Try a speed sensor from something earlier. I pulled my 500 out of an early Dakota that had a mechanical speedometer. The speed sensor had provisions for a cable.
Re: Speed Sensors on A518's [Re: MarkZ] #56927
04/21/08 06:33 PM
04/21/08 06:33 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
Here ya go!I am doing a 6.1 with a viper 6 speed in a early b body and this unit will work with your elect drive train and a cable speedo(a little pricy but accurate!!) It is a stand alone unit to drive the cable http://www.abbott-tach.com/cablex.htm
Re: Speed Sensors on A518's [Re: IMGTX] #56928
04/21/08 06:34 PM
04/21/08 06:34 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
I believe its a choice of the mechanical cable, or the electronic speed signal. I don't think you can run the Engine Controller without the electronic speed signal.
Re: Speed Sensors on A518's [Re: MarkZ] #56929
04/21/08 06:36 PM
04/21/08 06:36 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
Re: Speed Sensors on A518's [Re: DartGTDan] #56930
04/21/08 07:31 PM
04/21/08 07:31 PM
IMGTX Offline OP
IMGTX  Offline OP
Yeah I need the electronic signal and the mecanical cable. The device I got the other day looks like this. It's a speed sensor that connects in between the cable and the speedo gear housing. It would work except the wiring harness for the 94 has 3 wires and the speed sensor I have has two. I am hoping their is a way to adapt it.
Re: Speed Sensors on A518's [Re: IMGTX] #56931
04/21/08 08:05 PM
04/21/08 08:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The hole in the '94 tailhousing is the same as the older cable drive, just install the cable adapter and pinion from an older unit and you will have a threaded cable adapter.
Re: Speed Sensors on A518's [Re: John_Kunkel] #56932
04/22/08 05:55 AM
04/22/08 05:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What year is the trans you are putting in ? Ron
Re: Speed Sensors on A518's [Re: John_Kunkel] #56933
04/22/08 08:13 AM
04/22/08 08:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
since he's keeping the EFI, he needs both the VSS output AND the cable drive....
can you get wiring harnesses and find out what each wire is used for? maybe the 3rd wire is a ground that's not needed?
2017 Grand Cherokee Overland
Re: Speed Sensors on A518's [Re: patrick] #56934
04/22/08 09:56 AM
04/22/08 09:56 AM
dogdays Offline
dogdays  Offline
My thoughts exactly. The third wire may be nothing more than a ground.
For example: Oxygen sensors with three wires have one ground wire for the heating element and I presume the O2 sensor ground is through the case same as a one-wire.
However, four wire O2 sensors have two ground wires, one for the heater element and one for the sensor ground.
It could be the same way for the speed sensor.
R.
Re: Speed Sensors on A518's [Re: dogdays] #56935
04/22/08 04:53 PM
04/22/08 04:53 PM
IMGTX Offline OP
IMGTX  Offline OP
OK here is the Wiring diagram I have for the Vehicle Speed Sensor that came in the 94 Transmission I am using.
It appears that it recieves a Positive 8v, a Ground(sensor return) and a signal from the VSS.
Any good ideas?
Re: Speed Sensors on A518's [Re: IMGTX] #56936
04/22/08 06:25 PM
04/22/08 06:25 PM
Mopar part 4439097 is an in line sensor from
say an 89 M body. You should be able to use your
old pinion holder adapter into the new trans tail
and put the electical piece in line. I am not sure
if that sensor has a 5 volt signal but it may work. Check wiring for an 89 M body.
There is also 4740088 which if for a FWD and may be what you have, I'm not sure.Hope this helps.Try not using the black with blue tracer as this is the sensor ground.
Re: Speed Sensors on A518's [Re: IMGTX] #56937
04/23/08 08:39 AM
04/23/08 08:39 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Any good ideas?
can you get your hands on a similar vintage (or TBI) dakota or van service manual? IIRC those used a cable driven speedo and VSS
check that...look up a 1993 dodge dakota...it's VSS is standard motor SC108 (rockauto sells for $101)
http://www.partsamerica.com/ProductDetai...179&PTSet=A
a '93 dakota uses a magnum 3.9 or 5.2 engine, so it should work, you'll just need to find a wiring diagram for it.
Re: Speed Sensors on A518's [Re: patrick] #56938
04/23/08 11:34 AM
04/23/08 11:34 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Go to the junkyard and grab a speed sensor from a 4cyl FWD mopar. Judging by that pic you posted, the speed sensors look to be the same. They were also a 3-wire and many of them where a pass through design to accomodate a speedo cable as well.
Re: Speed Sensors on A518's #56939
04/23/08 04:02 PM
04/23/08 04:02 PM
IMGTX Offline OP
IMGTX  Offline OP
Thank you for all the info.
I haven't found the solution yet but with all this info I have lots of options.
If you have other suggestions let me know and I will let you know what I find to work.
Re: Speed Sensors on A518's [Re: IMGTX] #56940
05/21/10 09:55 AM
05/21/10 09:55 AM
Mays Landing, NJ
K
kim smith Offline
kim smith  Offline
K
Mays Landing, NJ
Check out http://cmacable.com. I worked with them through the entire process of modifying my ATV. They have A+ customer service and an excellent line of cable and restraints. If you are looking for Mechanical Cables cma is the way to go!
Re: Speed Sensors on A518's [Re: kim smith] #56941
05/21/10 10:26 AM
05/21/10 10:26 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just for reference, a 2 wire signal is probably providing a voltage with a round wave pattern (analog) and the change is often more waves with speed AND amplitude (voltage increase with speed increase.)
A 3 wire sensor is probably a hall effect. This sends out a square wave (digital) with pulses. Faster is more pulses.
383man [Re: RodStRace] #56942
05/22/10 10:59 AM
05/22/10 10:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes the 2 wire speed sensors send a small ac anolog voltage signal and the 3 wire sensors send a digital hall effect signal as they are hall effect sensors.
The 2 wire ac sensors in the tailhousing of the 518 is not used for the speedo but it is used for the electronic govenor as it needs to know the output shaft speed to control throttle pressure. These vehicles usually use the rear diff 2 wire sensor for the abs for the speedo. The abs module sends the signal to the pcm as it is either hard wired or sent over the buss. Then it goes to the cluster. Ron
