Speed Sensors on A518's
#56925
04/21/08 05:49 PM
04/21/08 05:49 PM
Posts: 12,229 Looking for a way out of Middl...
IMGTX
I am currently swapping an 5.9 magnum & A518 into my car. I am keeping the factory EFI, Computer etc. My current hitch is the speed Sensor. The OEM one in 94 was a 3 wire unit with no provisions for a speedometer cable. I want to use the factory Speedo but need the signal for the Engine Controller. I picked up a pass through speed sensor off of a Dodge van but it only has 2 wires instead of three. Is this adaptable or do I need to look elsewhere?
Re: Speed Sensors on A518's
[Re: IMGTX]
#56926
04/21/08 06:06 PM
04/21/08 06:06 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Try a speed sensor from something earlier. I pulled my 500 out of an early Dakota that had a mechanical speedometer. The speed sensor had provisions for a cable.
[Re: MarkZ]
#56927
04/21/08 06:33 PM
04/21/08 06:33 PM
Posts: 260 arizona
stockerbill
arizona
Here ya go!I am doing a 6.1 with a viper 6 speed in a early b body and this unit will work with your elect drive train and a cable speedo(a little pricy but accurate!!) It is a stand alone unit to drive the cable http://www.abbott-tach.com/cablex.htm
[Re: IMGTX]
#56931
04/21/08 08:05 PM
04/21/08 08:05 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The hole in the '94 tailhousing is the same as the older cable drive, just install the cable adapter and pinion from an older unit and you will have a threaded cable adapter.
[Re: IMGTX]
#56936
04/22/08 06:25 PM
04/22/08 06:25 PM
Mopar part 4439097 is an in line sensor from say an 89 M body. You should be able to use your old pinion holder adapter into the new trans tail and put the electical piece in line. I am not sure if that sensor has a 5 volt signal but it may work. Check wiring for an 89 M body. There is also 4740088 which if for a FWD and may be what you have, I'm not sure.Hope this helps.Try not using the black with blue tracer as this is the sensor ground.
[Re: IMGTX]
#56940
05/21/10 09:55 AM
05/21/10 09:55 AM
Posts: 2 Mays Landing, NJ
kim smith
Mays Landing, NJ
Check out http://cmacable.com. I worked with them through the entire process of modifying my ATV. They have A+ customer service and an excellent line of cable and restraints. If you are looking for Mechanical Cables cma is the way to go!
