Duster Dash #569209
01/01/10 11:40 PM
01/01/10 11:40 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Hello all, I have a 1972 Plymouth Duster 340 that I have the dash out. As you all remember in the 80's (and even earlier) it was cool to put in your in dash and under dash Stereo's CB's ect. which would usually create a lot of cutting and splicing of the wiring and drilling of holes in the dash. All of the plugs look good and I cleaned each one w/ some acid and have done a lot of work to straighten out the wiring issues. Soon I will be putting it back into the dash before I put the dash back in. The previous owner had had the wiring out and put it back in while the dash was still in the car. (the speedo was stolen as the car only had 59,000 miles on it) Needless to say, he performed some very sloppy work when he did it so he did not have it up in the dash correctly.
Does anyone on here have a picture of their dash (A-body) that shows how their wiring was installed? I just want to do a much neater job than I usually see from others. Plus, I hate sloppy wiring. Sometime in the future, I will spring for a new under dash wiring harness.
Also, I have a mint (no cuts, slices or cracks at all)'70 Duster wiring harness that I compaired to the '72 harness. Just a FYI they do not interchange as they are completely different (some people I talked to on here thought they might) Just thought i might save someone from making the same mistake.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Duster Dash [Re: reno340] #569210
01/01/10 11:42 PM
01/01/10 11:42 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Again, Any pics would be greatly appreciated!
Re: Duster Dash [Re: reno340] #569211
01/02/10 01:17 AM
01/02/10 01:17 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
heres what i got..dash out of car.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Duster Dash [Re: MonGoo$e] #569212
01/02/10 01:19 AM
01/02/10 01:19 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
maybe this will help to some effect.. btw..its a standard dash 73..
Re: Duster Dash [Re: MonGoo$e] #569213
01/02/10 01:20 AM
01/02/10 01:20 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
most of the wiring hanging is something that ties into the column wiring. that's an original harness..when i redid the dash i just removed and cleaned it, i had a break on the red ignition wire and that was it. i pretty much re-installed it how it naturally was bent to fit the dash.
Again, I hope it helps, might just have to take some time and study it.
Re: Duster Dash [Re: reno340] #569214
01/02/10 01:31 AM
01/02/10 01:31 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Long story short, yes it's easier/best to install the harness into the shell before it's installed and install it as a complete unit. It's also easier (but not required) to have the windshield out while you install it for ease of access to the forward dash frame screws.
The wire harness generally just lays along the bottom of the frame and is loosely held into place by hooks and bendable tabs, each "y" in the harness usually extends away from the main trunk of the harness toward whatever accessory they attach to. Pretty basic install. BTW, in 1972, the harnesses were not inique to 340 cars, all were basically the same.
Re: Duster Dash [Re: ScottSmith_Harms] #569215
01/02/10 08:44 PM
01/02/10 08:44 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
Yeah, I knew that. For some stupid reason, I keep identifying it as a 340 car when I ask questions on here. I really do appreciate the wealth of information at my fingertips here. Kinda funny. As much as I know about these cars, I keep on learning more and more about them every day.
Again, Thanks a whole lot!!! I couldn't do this without you all.
