Whats best way to make 1" round hole in vinyl doorpanel #569079
01/01/10 09:16 PM
01/01/10 09:16 PM
Anonymous OP
Anonymous OP
just got back my A990 hemi doorpanels back from legendary and there isnt any hole in the vinyl for the window crank and door handle.it needs a 1" round hole. i want these to be cut perfectly.Whats the best way to make a perfect circle in the vinyl.the cardboard backing has the hole already cut in it.. thanks
Re: Whats best way to make 1" round hole in vinyl doorpanel #569080
01/01/10 09:19 PM
01/01/10 09:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It's probably best if you just cut a small "X" cut with a razor that when placed in the center of your 1.00" circle is overall smaller than the hole required (legs of the "X" being a good 1/4" shy of hitting the edges of the circle). Install the handle and it should fit great with no worry of one side of the hole being off in any direction revealing a gap.
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: ScottSmith_Harms] #569081
01/01/10 09:26 PM
01/01/10 09:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
In adition to that, pull the four tabs from the x-cut through the hole & glue them to the backing.
Less chance of a rip spreading from the cuts that way.
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: Alaskan_TA] #569082
01/02/10 02:33 AM
01/02/10 02:33 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
And if you need to locate the hole in the vinyl using the backing as a reference, a sharp awl used from the backside will locate the center. Use something as a backer for the vinyl side, and a towel to protect the vinyl from the backer.
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: topside] #569083
01/02/10 09:33 AM
01/02/10 09:33 AM
Australia
dodgy Offline
dodgy  Offline
Australia
sharp hole punch and a whack with a hammer.
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: dodgy] #569084
01/02/10 09:40 AM
01/02/10 09:40 AM
Australia
dodgy Offline
dodgy  Offline
Australia
and if you can't find a 1" punch, what i do is get the right size ID pipe and grind a 45 deg edge on it, works a treet.
cheers Luke.
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: dodgy] #569085
01/02/10 12:09 PM
01/02/10 12:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
inner parts have enough trim around to cover any imperfection on cut. I would't worry about a perfect circle. Neither OEM parts were in that way in mostly of cases
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: NachoRT74] #569086
01/02/10 12:52 PM
01/02/10 12:52 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
You could make a template for the size hole you want,then use a detailing razor for a plastic model kit. My
'71 383HP FJ6 Charger SE
Re: Whats best way to make 1" round hole in vinyl doorpanel [Re: 71 FJ6 Charger] #569087
01/02/10 01:34 PM
01/02/10 01:34 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Take a piece of 1" thin walled tubing (copper tubing or electrical conduit) and grind the end to a fairly sharp bevel. heat the tubing NOT so it's red but hot enough to melt the vinyl. Aim carefully and touch the point where yo need the hole with the tube. Don't overheat the tube and don't hesitate as this will heat up too much vinyl and you won't be a happy camper. Practice in a test piece if you can. Done properly, it will leave a nice "finished" edge around the hole. Depending on the backing, you may need to finish cutting through with a razor or exact-o knife blade. Some vinyls have a cotton fabric back while others have a synthetic backing that will melt as easily as the vinyl.
