Leaking Rear Main Seal....Real Problem or Nuisance ?? #568777
01/01/10 04:19 PM
01/01/10 04:19 PM
Blanchard, OK
Real-Fury Offline OP
Blanchard, OK
Just wondered if a rear main seal that drips on a 451 stroker is a real problem that will lead to bigger problems or if it is merely a nuisance you have to put up with? Is the only fix to pull the engine and change out the rear seal?
Butch
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: Real-Fury] #568778
01/01/10 08:01 PM
01/01/10 08:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On a stick car, oil can get into the clutch & disc if the seal's leaking enough. On an automatic car it's no big deal. My Street Hemi's had a weeping rear main seal for years, but it hasn't bothered the clutch. It doesn't get driven a lot, so I just wipe it down from time to time so it doesn't leak on the floor or leave a film under the car. Most of my BB motors have weeped a little from their rear main seals.
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: topside] #568779
01/01/10 09:17 PM
01/01/10 09:17 PM
Blanchard, OK
Blanchard, OK
Thanks Topside,
This is a 727 car so I guess it will just be a nuisance. I just wanted to make sure it couldn't lead to a more serious problem.
Butch
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: Real-Fury] #568780
01/01/10 10:33 PM
01/01/10 10:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yeah nothing but an annoyance unless she's really gushing oil.
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: DaytonaTurbo] #568781
01/01/10 11:20 PM
01/01/10 11:20 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Why not just drop the pan and replace the seal?
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: Real-Fury] #568782
01/01/10 11:32 PM
01/01/10 11:32 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Don't think of it as a "Nuisance", think of it as a "Redneck undercoating system".
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: stumpy] #568783
01/02/10 12:08 AM
01/02/10 12:08 AM
Blanchard, OK
Blanchard, OK
Can you drop the pan without pulling the engine? Didn't think it was possible without pulling the engine which I would not want to do.
Butch
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: Real-Fury] #568784
01/02/10 12:36 PM
01/02/10 12:36 PM
florida
74fldart Offline
74fldart  Offline
florida
the pan can be dropped, you need to remove the center link to make it easier and the front bolts on the pan are a little rough to get to but it can be done.
Re: Leaking Rear Main Seal....Real Problem or Nuisance ?? [Re: 74fldart] #568785
01/02/10 12:43 PM
01/02/10 12:43 PM
most rear main leaks stay the same for a period of time but you'll eventually get tired of constantly adding oil & messing up yours (and other peoples') driveways. loosen/remove enough parts so you can jack up/raise the eng several inches so you can R&R the pan/seal.
Re: Leaking Rear Main Seal....Real Problem or Nuisance [Re: RapidRobert] #568786
01/02/10 04:27 PM
01/02/10 04:27 PM
sg66mopar Offline
sg66mopar  Offline
Some of that oil is going in your starter. Yeah, if this isn't a tube chassis race car it'll be some work but it can be done and your starter will thank you.
