727 puts on the brakes?? #568744
01/01/10 02:38 PM
01/01/10 02:38 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
shifting into high gear it's as if you start puushing on the brakes,this is during acceleration. whent to the archives, lotta good info in there but nothing addressed this problem, have the trans out, going to go through it to repair and refresh, any particular thing i should look for that might contribute to this problem?thanks for any professional advice.
Re: 727 puts on the brakes?? [Re: Lew] #568745
01/01/10 03:16 PM
01/01/10 03:16 PM
scratchnfotraction Offline
sounds like 2-3 over lap they talk about..
Re: 727 puts on the brakes?? [Re: scratchnfotraction] #568746
01/01/10 03:20 PM
01/01/10 03:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Shift overlap.. There are a few causes & fixes.. Basically a shift timing issue, it's trying to be in two gears at once...
Re: 727 puts on the brakes?? [Re: scratchnfotraction] #568747
01/01/10 03:25 PM
01/01/10 03:25 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
i read that, BUT we have been playing with this car for 2 yrs. never did this before, so has something broke or gotten pluged?
Re: 727 puts on the brakes?? [Re: Lew] #568748
01/01/10 05:01 PM
01/01/10 05:01 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Mine did that a few years ago. All I did was readjust the shift linkage. I was using a B&M pro stick shifter and a reverse manual valve body. Put trans in 3rd gear and adjust linkage there instead of in first as the directions say. Took care of it.
Re: 727 puts on the brakes?? [Re: Lew] #568749
01/01/10 05:12 PM
01/01/10 05:12 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A good reprogramming kit like the Transgo TF-2 will help eliminate severe overlap.
Re: 727 puts on the brakes?? [Re: Lew] #568750
01/01/10 05:18 PM
01/01/10 05:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If you have a 5.0 leaver (or even a 4.2) they will sometimes hang up if out of adjustment.
