Page 1 of 6 1 2 3 4 5 6
505 back together with Mancini heads #56742
04/19/08 12:52 AM
04/19/08 12:52 AM
AndyF Offline OP
AndyF  Offline OP
These are the Mancini ported heads that they sell for $2650. Basically MP '452' heads with a CNC port job by Modern. Nice deal for some really up to date hardware. I replaced the valve springs with Comp 26094's since I'll be running a .600 lift street roller cam.
Just waiting for the new Super Victor intake to show up and then we're off to the dyno.
Re: 505 back together with Mancini heads [Re: AndyF] #56743
04/19/08 12:54 AM
04/19/08 12:54 AM
AndyF Offline OP
AndyF  Offline OP
Here is a close up of the retainers. These are the new tool steel retainers from Comp. Part number 1732, cost about $170 from Mancini Racing. They weigh 22 grams which is only 2 grams heavier than Ti retainers but they are a lot cheaper. Also, they hold up to flat wire dampers better than the Ti retainers. I'll probably start using these retainers in any motor that takes a dual spring.
Re: 505 back together with Mancini heads [Re: AndyF] #56744
04/19/08 12:58 AM
04/19/08 12:58 AM
hartsburg mo
biggerredz71 Offline
hartsburg mo
looks nice.
Re: 505 back together with Mancini heads [Re: AndyF] #56745
04/19/08 01:06 AM
04/19/08 01:06 AM
AndyF Offline OP
AndyF  Offline OP
Here is the top end kit ready to put on. Comp street roller cam, specs are 260/266 with .588/.597 lift. The MCH ported heads and I'll be using the Super Victor intake and a Dominator. Comp rocker arms with the 1.50 ratio but I might try a 1.60 rocker arm just for fun. The valve springs will handle up to .650 lift so I might do it, just requires a new set of pushrods and an extra hour or so on the dyno.
I think I'm going to try these Edelbrock head gaskets but I'm worried if the bore is big enough. If it isn't I'll have to come up with another plan. Maybe reuse my Cometics from the last dyno test since I know they work.
Compression is around 12.5 so she'll probably make some power. Should make plenty of torque with the tiny ports and the small cam!
Re: 505 back together with Mancini heads [Re: AndyF] #56746
04/19/08 01:23 AM
04/19/08 01:23 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Boy, I really have to step up to a decent valley cover.
Re: 505 back together with Mancini heads [Re: AndyF] #56747
04/19/08 01:38 AM
04/19/08 01:38 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Andy , where did you get those rocker shaft studs?
Re: 505 back together with Mancini heads [Re: AndyF] #56748
04/19/08 01:44 AM
04/19/08 01:44 AM
SoCal
Brian Hafliger Offline
SoCal
I used those retainers in w2stroker's engine that made 685HP with a sizeable roller in it. Worked very good.
I agree, I think they are the only way to go.
Brian
Brian Hafliger
Re: 505 back together with Mancini heads [Re: rowin4] #56749
04/19/08 01:45 AM
04/19/08 01:45 AM
AndyF Offline OP
AndyF  Offline OP
MagnumHP carries the standard rocker arm shaft stud kit but these are super trick studs from T&D with the turned down waist.
Re: 505 back together with Mancini heads [Re: AndyF] #56750
04/19/08 01:47 AM
04/19/08 01:47 AM
seems like you'd only need 2 turned down like that. i wonder why they do all of them?
Re: 505 back together with Mancini heads [Re: Brian Hafliger] #56751
04/19/08 01:48 AM
04/19/08 01:48 AM
AndyF Offline OP
AndyF  Offline OP
Comp doesn't have a tool steel retainer yet for a triple spring but I bet it is just a matter of time. Another nice thing about these retainers is that they are quite a bit thinner which means more clearance for the rocker arm. I guess that Manley is also selling this same (or similiar) retainer now so it must be catching on.
Re: 505 back together with Mancini heads #56752
04/19/08 01:50 AM
04/19/08 01:50 AM
AndyF Offline OP
AndyF  Offline OP
[quote
Actually you need three turned down for adequate oil flow with the small T&D shaft but the end ones do not need to be turned down since the oil doesn't flow past them. I bet T&D provides the whole kit turned down since they don't trust their customers to assemble the setup correctly.
Re: 505 back together with Mancini heads [Re: AndyF] #56753
04/19/08 01:55 AM
04/19/08 01:55 AM
[quote
that makes sense. no way to mess it up with them all that way. i forgot about the smaller shaft of the T&D's.
Re: 505 back together with Mancini heads #56754
04/19/08 06:42 AM
04/19/08 06:42 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Andy, what distributor and ignition box are you running ?? We have your wires finally done. Taking pics of them today, and sending them off..How much do you think they would need to be added to fit them on an engine in a car ??
Hi Rick,
I measured up the wires for the Jesel belt drive distributor. The following lengths should work pretty well with dyno headers and Indy heads. The wires will loop down under the heads which works great on the dyno but might not work in a car.
1 wire at 24 inches, 3 at 33.5 inches, 2 at 38 inches and 2 at 41 inches. The Jesel distributor has HEI style terminals. The wires need to have 90 degree boots on both ends. The measurements are from center to center of the boot. (center of the spark plug to center of the HEI terminal)
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 505 back together with Mancini heads [Re: AndyF] #56755
04/19/08 10:12 AM
04/19/08 10:12 AM
Idaho
Runner Offline
Runner  Offline
Idaho
andy, i thought your valley plate wouldnt work with e-heads?. arent the 452 heads just e heads with straight plugs?
Re: 505 back together with Mancini heads [Re: Runner] #56756
04/19/08 10:48 AM
04/19/08 10:48 AM
AndyF Offline OP
AndyF  Offline OP
Runner - I don't think the plate will work with the E heads. I mocked it up in the photo and decided to go with a standard valley pan.
Rick - cool deal on the wires. We run MSD ignition on the dyno with a Jesel distributor.
Re: 505 back together with Mancini heads [Re: AndyF] #56757
04/19/08 08:10 PM
04/19/08 08:10 PM
AndyF Offline OP
AndyF  Offline OP
Here is the street roller cam going in. This cam is pretty close to the MP .590 in terms of 050 duration and lift. Specs on the cam are 260/266 at 050 and .588/.597 lift. The MP .590 is 265/265 and .590. But based on how these lobes look I've got to assume that this street roller has a ton more duration at .200 and .300. I'll measure it just to see.
Re: 505 back together with Mancini heads [Re: AndyF] #56758
04/19/08 08:39 PM
04/19/08 08:39 PM
Wis.
rlm2268 Offline
rlm2268  Offline
Wis.
Hey Andy, What is the valve timing at .050 and what lobe center is it ground on?
Thank's
Re: 505 back together with Mancini heads [Re: rlm2268] #56759
04/19/08 08:50 PM
04/19/08 08:50 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Any pics of the cam button arrangement??
I'm Gumby dammit!
Re: 505 back together with Mancini heads [Re: AndyF] #56760
04/19/08 09:52 PM
04/19/08 09:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Andy the mp 590 is actually around 271 to 272 @ .050 at .200 its 179* Both me and Porter got the same numbers. mike
Re: 505 back together with Mancini heads [Re: rlm2268] #56761
04/19/08 10:11 PM
04/19/08 10:11 PM
AndyF Offline OP
AndyF  Offline OP
Thank's
The cam is ground on 108 centers. I'll probably install it 4 degrees advanced although Comp recommended 2 degrees advanced.
