Dakota Transmission #567000
12/30/09 03:12 PM
12/30/09 03:12 PM
Lapeer, Michigan
hammer Offline OP
hammer  Offline OP
Lapeer, Michigan
I have a 1993 Dakota 4x4 with the 318 V8 Automatic transmission. The transmission is bad. My questions are:
1) Can this truck be towed on a tow dolly without any more damage being done to the transmission.
2) What year(s) of automatic transmissions will work on this truck or should I just stick with the 93? I was hoping that a newer trans would work.
Thanks,
Bill
Re: Dakota Transmission [Re: hammer] #567001
12/30/09 03:32 PM
12/30/09 03:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the drive shaft from the rearend and tie it up out of the way. I think your's was the last year for the three prong od and lock up wiring connector. The newer trans used a differnt wiring setup IIRC.
Re: Dakota Transmission [Re: stumpy] #567002
12/30/09 11:07 PM
12/30/09 11:07 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
96 was the first year of the RE's instead of the RH's in the trucks. so any lockup, pre '96 tranny should work.
2017 Grand Cherokee Overland
Re: Dakota Transmission [Re: patrick] #567003
12/31/09 12:59 AM
12/31/09 12:59 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
91 and older need a notch ground in the belhousing for the crank sensor, about 5 minutes a die grinder and an aluminum cutter will fix that.
96 and newer have the big plug with way too many wires.
Any dakota or Ram or van a-500 in those year ranges will work (or easily be made to work).
The jeep A-500 guts will all work but the 4.0 uses a different bolt pattern all together and the 5.2 jeep has the starter on the wrong side and will cause exhaust fitment issues if you try to swap the starter to the other side.
You can tow it without a trailer and with out doing anything but put the transfer case in neutral
