Solid Lifters #566334
12/29/09 09:49 PM
12/29/09 09:49 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
What would be the best way to go? I am thinking on trying the ole MP .528 or .557 solid cam for my 440 but I need to choose between the shubeck lifters or the edm style lifters! What would you run? This is for the street/strip. Thanxs
Re: Solid Lifters [Re: JohnnyBeGood] #566335
12/29/09 10:02 PM
12/29/09 10:02 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
If I had to use a flat tappet, I would use the EDM's. It's basically the old well proven design with a slight, but probably useful modification. I've no experience with the Shubeck's, but there are reports of the ceramic face failing and making a major mess. The pressurized oil from the EDM's can only do good things IMO.
Re: Solid Lifters [Re: JohnnyBeGood] #566336
12/30/09 02:19 AM
12/30/09 02:19 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
shubeck lifters with a MP cam is a waste of money imho...run the .557 with some EDM's if you want.
Re: Solid Lifters [Re: Quicksilver440] #566337
12/30/09 02:28 AM
12/30/09 02:28 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
What's wrong with the included solids? I have a set of Johnsons that came with the Racer Brown I'm going to run. I've run flat hyd. lifters with no issues. Take the time to set the lifters up, mark them, and verify they're all rotating in the bores.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Solid Lifters [Re: R70RUNNER] #566338
12/30/09 02:33 AM
12/30/09 02:33 AM
Central Valley, CA.
Central Valley, CA.
True enough...they will work doing as you suggest and running the right oil.
Re: Solid Lifters [Re: Quicksilver440] #566339
12/30/09 01:40 PM
12/30/09 01:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 440 Comp cam and Comp solids.Been in for 9 years and no problems.I run either KendallGT1 or now full synthetic Valvoline.Street and strip.Cam still looks like new.My shop did blueprint the block and lower end.Rocky
Chrysler Firepower
Re: Solid Lifters [Re: therocks] #566340
12/30/09 02:14 PM
12/30/09 02:14 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'll be running an Engle flat-solid this year. After talking it over with the guys at Engle, I'm just going with the solids they sent me and a good zinc fortified oil.
If everything is operating correctly, A solid cam motor should be just fine. If something is wrong in your valvetrain, I dont think a little oil leaking from the bottom of the lifter is going to fix it.
Re: Solid Lifters [Re: StealthWedge67] #566341
12/30/09 04:07 PM
12/30/09 04:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
EDM's oil the face of the lobe/lifter which really helps potential lobe/lifter failure.
I have a new set of EDM's in the box I want to sell.
These are $180 through Competition Products, buy them from me and save some money and help a fellow racer.... $150 Shipped in the States..
PM me if your interested.
Re: Solid Lifters [Re: Bob_Coomer] #566342
12/30/09 04:08 PM
12/30/09 04:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
