Undersized Chain #566324
12/29/09 09:43 PM
12/29/09 09:43 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I have been told if you use aftermarket caps and line bore and hone you will need to use an undersize chain is this correct? I bought a nice 70 block but some of the original caps were missing so I bought a set of milodon caps and studs. Thanxs
Re: Undersized Chain [Re: JohnnyBeGood] #566325
12/29/09 09:49 PM
12/29/09 09:49 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
They do make undersized chains in .005 and .010. You could just use a chain tensioner and use the chain you already have.
Howard
Re: Undersized Chain [Re: mrsmallblock] #566326
12/30/09 05:42 PM
12/30/09 05:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I've seen the list, but how does that work? The chain is still #35, which means the links are still exactly .375000" apart, and you can only change the number of links in 1/2-link increments?
Boffin Emeritus
Re: Undersized Chain [Re: polyspheric] #566327
12/30/09 06:25 PM
12/30/09 06:25 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Well you normally buy the undersized chain and sprockets as a matched set - I believe the the sprockets are machined on a slightly larger diameter
Re: Undersized Chain [Re: polyspheric] #566328
12/30/09 07:04 PM
12/30/09 07:04 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
That's a good point. You can buy an undersized chain to use with a standard sprocket set.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
