Re: heads look worse after hot tank
[Re: darkrider2]
#565616
12/29/09 08:40 AM
12/29/09 08:40 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I have them airless-shot blasted. Most cleaners now-a-days are not really strong anymore due to EPA mandates and DEP fines. I watched a program once on a southern CA shop building an engine for Boyd Coddington and they used a pressure washer to clean the block. That would be a huge fine if anyone saw you doing that as a business in CT unless you were reclaiming all the residue.
[Re: moper]
#565618
12/29/09 08:53 AM
12/29/09 08:53 AM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
This is the route I am taking ... I bought a PW with soap injection. I will probably get a better job-done PLUS a hot-tank will eat-up the cam-bearings and the intermediate bushing.
[Re: darkrider2]
#565619
12/29/09 09:46 AM
12/29/09 09:46 AM
Posts: 4,799 ILL
MLR426
ILL
shot abraded this block and came out great. A tip is to thoroughly soak your parts with WD40 and cover them with trash bags after and they will be amazingly clean indefinitely
You will need to lightly hone those lifter bores. I also don't believe in steel shot braiding the block with out the main caps on, becauce it does cause some stress relieving in the block. Check cam fit with bearings installed before going any further.
logan426
[Re: Stanton]
#565622
12/29/09 10:57 AM
12/29/09 10:57 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
How do they protect the machined surfaces when shot blasting?
The times I have had it don't they don't , but the blocks I had done needed full machining anyway so it wasn't a big deal.
I did make some flat plates out of .090 alum to cover the decks on one block I had done .
[Re: GTXKen]
#565624
12/29/09 12:30 PM
12/29/09 12:30 PM
moper
Columbia, CT
I used large diameter rubber hose in the main bores with the caps torqued in place and slit pcs of heater hose in the lifter bores. With those in place there was no damage.
