heads look worse after hot tank #565613
12/29/09 02:55 AM
12/29/09 02:55 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
took a set of heads in to get hot tanked, they were not very greasy just wanted the old paint off and carbon out of the bowls and heat crossover. well picked them up and looks like it removed the paint but didn't touch much of the carbon or light flash rust, in fact they look more rusted than before. what gives? last few times i had heads cleaned they came out like new.
Re: heads look worse after hot tank [Re: ademon] #565614
12/29/09 03:13 AM
12/29/09 03:13 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Likely in the past the machine shop used a hot tank filled with a caustic solution but now in the interest of being a "green" world the EPA has made that equipment illegal so instead your heads were put into an industrial dish washer... If you pay for the next step some form of shot blasting they would be free of rust and carbon deposits...
Re: heads look worse after hot tank [Re: 1_WILD_RT] #565615
12/29/09 07:01 AM
12/29/09 07:01 AM
California
darkrider2 Offline
darkrider2  Offline
California
shot abraded this block and came out great. A tip is to thoroughly soak your parts with WD40 and cover them with trash bags after and they will be amazingly clean indefinitely
Re: heads look worse after hot tank [Re: darkrider2] #565616
12/29/09 08:40 AM
12/29/09 08:40 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I have them airless-shot blasted. Most cleaners now-a-days are not really strong anymore due to EPA mandates and DEP fines. I watched a program once on a southern CA shop building an engine for Boyd Coddington and they used a pressure washer to clean the block. That would be a huge fine if anyone saw you doing that as a business in CT unless you were reclaiming all the residue.
Re: heads look worse after hot tank [Re: moper] #565617
12/29/09 08:44 AM
12/29/09 08:44 AM
scratchnfotraction Offline
my machine shop bakes it in and oven,then rinses the block and air dries it.
the carbon turns to powder and cleans right out,then they wash it down with purple cleaner and rinse
Re: heads look worse after hot tank [Re: moper] #565618
12/29/09 08:53 AM
12/29/09 08:53 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
This is the route I am taking ... I bought a PW with soap injection. I will probably get a better job-done PLUS a hot-tank will eat-up the cam-bearings and the intermediate bushing.
Re: heads look worse after hot tank [Re: darkrider2] #565619
12/29/09 09:46 AM
12/29/09 09:46 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
You will need to lightly hone those lifter bores.
I also don't believe in steel shot braiding the block with out the main caps on, becauce it does cause some stress relieving in the block.
Check cam fit with bearings installed before going any further.
logan426
Re: heads look worse after hot tank [Re: MLR426] #565620
12/29/09 10:28 AM
12/29/09 10:28 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Thanks, thats what i figured, so its just a waist of $$ to just ask for a hot tank. other than if you want old paint removed. It did remove the paint .
Re: heads look worse after hot tank [Re: ademon] #565621
12/29/09 10:50 AM
12/29/09 10:50 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How do they protect the machined surfaces when shot blasting?
Re: heads look worse after hot tank [Re: Stanton] #565622
12/29/09 10:57 AM
12/29/09 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The times I have had it don't they don't , but the blocks I had done needed full machining anyway so it wasn't a big deal.
I did make some flat plates out of .090 alum to cover the decks on one block I had done .
Re: heads look worse after hot tank [Re: JohnRR] #565623
12/29/09 11:26 AM
12/29/09 11:26 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I'm having one cleaned and pressure tested now, they bake them and then tank them at this shop.
When I've done them at home I have just soaked them with Gunk and then used my pressure washer hooked up to hot water, turns out amazingly clean.
Re: heads look worse after hot tank [Re: GTXKen] #565624
12/29/09 12:30 PM
12/29/09 12:30 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I used large diameter rubber hose in the main bores with the caps torqued in place and slit pcs of heater hose in the lifter bores. With those in place there was no damage.
